kindly help me in applying the digital bandpass filter (range 0.3Hz to 10 Hz) on ADXL345 accelerometer real-time readings.
Apply low pass filter on ADXL345
- sj_remington
Re: Apply low pass filter on ADXL345
You can set the ADXL345 BW_RATE device register (0x2C) to 0b1000, for 25 Hz data rate (bandwidth 12.5 Hz).
For more information, be sure to consult the ADXL345 data sheet.
- CircuitFlyer
If the micro-controller board you are using includes the built in module ulab then I'd suggest reading https://learn.adafruit.com/ulab-crunch- ... cuitpython. The Filter Example: Measuring barometric pressure is likely very similar to what you require. I found it very helpful when I needed to apply a low pass filter to an accelerometer output. I use https://fiiir.com/ to determine the filter coefficients required.
