The following sample code for Adabox 19 with the MacroPad is failing.
Here is the code.....
from adafruit_macropad import MacroPad
macropad = MacroPad()
text_lines = macropad.display_text(title="MacroPad Info")
while True:
key_event = macropad.keys.events.get()
if key_event and key_event.pressed:
text_lines[0].text = "Key {} pressed!".format(key_event.key_number)
text_lines[1].text = "Rotary encoder {}".format(macropad.encoder)
text_lines[2].text = "Encoder switch: {}".format(macropad.encoder_switch)
text_lines.show()
_____________________________________________________________________________
Here is the error....
code.py output:
File "code.py", line 1, in <module>
File "adafruit_macropad.py", line 71, in <module>
File "adafruit_simple_text_display.py", line 31, in <module>
ImportError: no module named 'adafruit_display_text.bitmap_label'
Code done running.
I'm using Circuit Phython 7 and it's associated library.
Please assist.
MacroPad Sample Code is Failing
- dsheeran
Re: MacroPad Sample Code is Failing
Please disregard this. One of the libraries copied over empty and that was the problem. It's working now. Thanks anyway.
- dastels
I was about to suggest checking the libs. It's a good idea to update them regularly (even daily) for such a new product. Fixes and enhancements happen a lot for new board support.
