MLX90614, Raspberry Pi 4B, and try_lock issue
dframe
Post by dframe »
I have an issue using the MLX90614 Circuit Python library on my Raspberry Pi 4B. I have the MLX connected and it can be seen with i2cdetect from the command line.
Any help would be greatly appreciated!
Code (from the comments in the library code):
import board
import adafruit_mlx90614
i2c = board.I2C
mlx = adafruit_mlx90614.MLX90614(i2c)
temperature = mlx.ambient_temperature
print (temperature)
Traceback:
sudo python3 firstTempTest.py
File "firstTempTest.py", line 6, in <module>
File "/home/pi/projects/annealer/adafruit_mlx90614.py", line 108, in __init__
self._device = i2c_device.I2CDevice(i2c_bus, address)
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 50, in __init__
self.__probe_for_device()
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 151, in __probe_for_device
while not self.i2c.try_lock():
AttributeError: 'function' object has no attribute 'try_lock'
Thanks in advance!
dframe
Re: MLX90614, Raspberry Pi 4B, and try_lock issue
Post by dframe »
Looks like I was being a bonehead. The issue was in line 5, I needed to use parentheses to call the function, rather than use the function as a value. I missed that as I copied it over. Problem solved.
