help python rockblock rockblock_recv_text.py
hector_alsaago
Post by hector_alsaago »
hello I need help with the code rockblock_recv_text.py I am trying to get what I receive as a message to store in a .txt so far I have the following code but it fails me in the line message_received = rb.text_in ... I don't know almost anything in python If you can help me, I would be very grateful. I leave the code that I have:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# pylint: disable=wrong-import-position
import time
# CircuitPython / Blinka
import board
#uart = board.UART()
#uart.baudrate = 19200
import serial
uart = serial.Serial("/dev/serial0", 19200)
# via USB cable
# import serial
# uart = serial.Serial("/dev/ttyUSB0", 19200)
from adafruit_rockblock import RockBlock
rb = RockBlock(uart)
# try a satellite Short Burst Data transfer
print("Talking to satellite...")
status = rb.satellite_transfer()
# loop as needed
retry = 0
while status[0] > 8:
    time.sleep(10)
    print(retry, status)
    retry += 1
print("\nDONE.")
# get the text
print(rb.text_in)
from io import open
mensaje_recibido=rb.text_in
archivo_texto=open("recibido.txt","w")
archivo.write(mensaje_recibido)
archivo.close()
adafruit_support_carter
Re: help python rockblock rockblock_recv_text.py
What is the full text of the error message you are getting?
