Hello all,
I have a feather S2 running circuitpython 6.3.0. I tried interfacing with a PN532 using SPi and kept getting "PN532 not found" errors. I double checked all the soldering, wiring and also tried a different pin besides D5. I switched the wiring to I2C and it worked with no problems. I've rebooted and scanned tags at least 10 times with no problems or errors. I'm using the pn532_simpletest.py code from the adafruit-circuitpython-bundle.
PN532 and feather S2 SPi not working
- danhalbert
Re: PN532 and feather S2 SPi not working
If you are familiar with Arduino, you could try SPI mode with the Arduino library, to see if that is working. If it isn't, then I would suspect wiring or a board setup issue.
If you have another non-ESP32-S2 CircuitPython board, you could also try it with that, to see if it's related to the choice of board.
