Does Circuit Python 6.3.0 for the Arduino Nano RP2040 Connect support the RGB LED on the Arduino Nano RP2040 Connect? Is there any example code available? Will it be supported in CP version 7.0.0?
TIA
Bruce
RGB LED on Arduino Nano RP2040 Connect
- mikeysklar
Re: RGB LED on Arduino Nano RP2040 Connect
Yes, both releases (6.3.0 and 7.x) support the built-in LED.
https://learn.adafruit.com/circuitpytho ... nect/blink
I did not see in the documentation that this is an RGB LED.
import time
import board
from digitalio import DigitalInOut, Direction
# LED setup for onboard LED
led = DigitalInOut(board.LED)
led.direction = Direction.OUTPUT
while True:
led.value = True
print("led on")
time.sleep(1)
led.value = False
print("led off")
time.sleep(1)
- blakebr
Mike,
There are two LED devices on the 'Arduino Nano RP2040 Connect' board. A single amber LED, which your code works with, and a triple RGB LED. It is not a NeoPixel device. It is three LEDs in a package driven through the WiFi NINA chip. Commands must be given to the NINA device to cause the triple LED to light via NINA pins 25, 26, and 27. There is a driver that works through a micropython version. It is beyond my skills to reverse engineer it and make a library for CircuitPython. Here is code from https://github.com/adafruit/circuitpython/pull/4802. I have not been able to make this code work on my device using CircuitPython 6.3.0. Do I need to move up to the alpha version of CircuitPython 7.0.0? The line with "from micropython import const" should be noted.
The 'Arduino Nano RP2040 Connect' board with CP 6.3.0 easily drives NeoPixel devices.
Thanks for your help.
Bruce
Bruce
# WIFININA spi driver https://github.com/arduino-libraries/WiFiNINA/blob/master/src/utility/spi_drv.cpp
# Commands https://github.com/arduino-libraries/WiFiNINA/blob/master/src/utility/wifi_spi.h
# Adafruit esp32spi https://github.com/adafruit/Adafruit_CircuitPython_ESP32SPI
# NINA 27, 26, 25 are R, G, B
from machine import Pin
from machine import SPI
import time
_START_CMD = const(0xe0)
_END_CMD = const(0xee)
_ERR_CMD = const(0xef)
_REPLY_FLAG = const(1<<7)
_CMD_FLAG = const(0)
_SET_PIN_MODE = 0x50
_SET_DIGITAL_WRITE = 0x51
_SET_ANALOG_WRITE = 0x52
_GET_DIGITAL_READ = 0x53
_GET_ANALOG_READ = 0x54
ESP_BUSY = Pin(10, Pin.IN)
ESP_RESET = Pin(3, Pin.OUT, False)
ESP_CS = Pin(9, Pin.OUT, True)
ESP_GPIO0 = Pin(2)
ESP_MISO = Pin(8)
ESP_MOSI = Pin(11)
ESP_SCK = Pin(14)
LEDR = 27
LEDG = 25
LEDB = 26
spiwifi = SPI(1, baudrate=100000, sck=ESP_SCK, mosi=ESP_MOSI, miso=ESP_MISO)
def reset():
ESP_GPIO0.init(Pin.OUT)
ESP_GPIO0.value(True)
ESP_CS.high()
ESP_RESET.low()
time.sleep(0.01)
ESP_RESET.high()
time.sleep(0.75)
ESP_GPIO0.init(Pin.IN)
print("ESP32 reset")
def wait_ready():
wait_status = ESP_BUSY.value()
while wait_status:
time.sleep(0.05)
def read_response():
response = []
response_bytes = []
bytes_read = 0
max_read = 32
wait_ready()
ESP_CS.low()
while True:
read_byte = spiwifi.read(1)
response_bytes.append(read_byte)
if read_byte == bytes([_END_CMD]):
break
if read_byte == bytes([_ERR_CMD]):
raise RuntimeError('Error waiting on WiFi Command')
bytes_read += 1
if bytes_read > max_read:
raise RuntimeError('Error waiting on WiFi command')
ESP_CS.high()
num_params = response_bytes[2]
index = 3
for _ in num_params:
length = int.from_bytes(response_bytes[index], "little")
newparam = response_bytes[index+1:index+1+length]
index += 1 + length
response.append(b''.join(newparam))
return response
def send_command(cmd, params=[], num_params=-1):
if num_params < 0:
num_params = len(params)
total_bytes = 3 + num_params + 1
for p in params:
pbytes = bytearray(p)
total_bytes = total_bytes + len(pbytes)
sendbuffer = bytearray(total_bytes)
sendbuffer[0] = _START_CMD
sendbuffer[1] = cmd & ~_REPLY_FLAG
sendbuffer[2] = num_params
index = 3
for p in params:
lenpbytes = len(pbytes)
sendbuffer[index] = lenpbytes
sendbuffer[index+1:index+1+lenpbytes] = pbytes
index += 1+lenpbytes
sendbuffer[index] = _END_CMD
wait_ready()
ESP_CS.low()
spiwifi.write(sendbuffer)
ESP_CS.high()
def set_ninapin_mode(pin, mode):
send_command(_SET_PIN_MODE, [[pin], [mode]])
return read_response()
def ninapin_digital_write(pin, value):
if value == 0:
value = 1
else:
value = 0
send_command(_SET_DIGITAL_WRITE, [[pin], [value]])
reset()
for pin in [LEDR, LEDG, LEDB]:
set_ninapin_mode(pin, Pin.OUT)
ninapin_digital_write(pin, 0)
while True:
time.sleep(0.25)
ninapin_digital_write(LEDR, 1)
ninapin_digital_write(LEDG, 0)
ninapin_digital_write(LEDB, 0)
time.sleep(0.25)
ninapin_digital_write(LEDR, 0)
ninapin_digital_write(LEDG, 1)
time.sleep(0.25)
ninapin_digital_write(LEDB, 1)
- mikeysklar
Bruce,
I think the esp32spi module will be the CircuitPython path to control the Nano RP2040 RGB LED. What I don't see that the Arduino world and Micropython world seem to have is a ninapin definnition that hides all the layers that need to be gone through to toggle the LED pins. It might make sense to open an issue here requesting ninapin support to control the RGB LED.
https://github.com/adafruit/Adafruit_Ci ... SPI/issues
arduino:
https://forum.arduino.cc/t/example-mult ... d/865075/7
micropython:
https://github.com/adafruit/circuitpyth ... -852197442
arduino:
micropython:
