Thanks. That helps a lot. Still not sure what the actual issue is though. Not sure why you're ending up with a NoneType object there. The library should be taking care of that for you. Here's where it actually creates the library:
https://github.com/adafruit/Adafruit_Ci ... ad.py#L407
Can you try updating to the 7.0.0 release version (you're on alpha 5):
https://circuitpython.org/board/adafrui ... ad_rp2040/
And also update your libraries to latest as well:
https://circuitpython.org/libraries
And then just see if the the problems repeats.
Help Needed: Text output from the Macropad RP2040
- adafruit_support_carter
- demsecure
Re: Help Needed: Text output from the Macropad RP2040
Will try that and report back here.
Really appreciate all the time and help here
- demsecure
That worked!.. totally works as I expect now! This is fantastic! So grateful for the help!
Cool. Glad it's working. Still a bit of mystery what the original issue was. But you're working now. Thanks for letting us know. Have fun!
