Yes.. sorry I wasn't clear. Here's my code.py
A fairly straightforward macro/hotkey program for Adafruit MACROPAD.
Macro key setups are stored in the /macros folder (configurable below),
load up just the ones you're likely to use. Plug into computer's USB port,
use dial to select an application macro set, press MACROPAD keys to send
key sequences.
# pylint: disable=import-error, unused-import, too-few-public-methods
import os
import displayio
import terminalio
from adafruit_display_shapes.rect import Rect
from adafruit_display_text import label
from adafruit_macropad import MacroPad
# CONFIGURABLES ------------------------
MACRO_FOLDER = '/macros'
# CLASSES AND FUNCTIONS ----------------
class App:
""" Class representing a host-side application, for which we have a set
of macro sequences. Project code was originally more complex and
this was helpful, but maybe it's excessive now?"""
def __init__(self, appdata):
self.name = appdata['name']
self.macros = appdata['macros']
def switch(self):
""" Activate application settings; update OLED labels and LED
colors. """
group[13].text = self.name # Application name
for i in range(12):
if i < len(self.macros): # Key in use, set label + LED color
macropad.pixels[i] = self.macros[i][0]
group[i].text = self.macros[i][1]
else: # Key not in use, no label or LED
macropad.pixels[i] = 0
group[i].text = ''
macropad.keyboard.release_all()
macropad.pixels.show()
macropad.display.refresh()
# INITIALIZATION -----------------------
macropad = MacroPad()
macropad.display.auto_refresh = False
macropad.pixels.auto_write = False
# Set up displayio group with all the labels
group = displayio.Group()
for key_index in range(12):
x = key_index % 3
y = key_index // 3
group.append(label.Label(terminalio.FONT, text='', color=0xFFFFFF,
anchored_position=((macropad.display.width - 1) * x / 2,
macropad.display.height - 1 -
(3 - y) * 12),
anchor_point=(x / 2, 1.0)))
group.append(Rect(0, 0, macropad.display.width, 12, fill=0xFFFFFF))
group.append(label.Label(terminalio.FONT, text='', color=0x000000,
anchored_position=(macropad.display.width//2, -2),
anchor_point=(0.5, 0.0)))
macropad.display.show(group)
# Load all the macro key setups from .py files in MACRO_FOLDER
apps = []
files = os.listdir(MACRO_FOLDER)
files.sort()
for filename in files:
if filename.endswith('.py'):
try:
module = __import__(MACRO_FOLDER + '/' + filename[:-3])
apps.append(App(module.app))
except (SyntaxError, ImportError, AttributeError, KeyError, NameError,
IndexError, TypeError) as err:
pass
if not apps:
group[13].text = 'NO MACRO FILES FOUND'
while True:
pass
last_position = None
last_encoder_switch = macropad.encoder_switch_debounced.pressed
app_index = 0
apps[app_index].switch()
# MAIN LOOP ----------------------------
while True:
# Read encoder position. If it's changed, switch apps.
position = macropad.encoder
if position != last_position:
app_index = position % len(apps)
last_position = position
# Handle encoder button. If state has changed, and if there's a
# corresponding macro, set up variables to act on this just like
# the keypad keys, as if it were a 13th key/macro.
macropad.encoder_switch_debounced.update()
if encoder_switch != last_encoder_switch:
last_encoder_switch = encoder_switch
if len(apps[app_index].macros) < 13:
continue # No 13th macro, just resume main loop
key_number = 12 # else process below as 13th macro
pressed = encoder_switch
else:
event = macropad.keys.events.get()
if not event or event.key_number >= len(apps[app_index].macros):
continue # No key events, or no corresponding macro, resume loop
key_number = event.key_number
pressed = event.pressed
# If code reaches here, a key or the encoder button WAS pressed/released
# and there IS a corresponding macro available for it...other situations
# are avoided by 'continue' statements above which resume the loop.
sequence = apps[app_index].macros[key_number][2]
if pressed:
if key_number < 12: # No pixel for encoder button
macropad.pixels[key_number] = 0xFFFFFF
for item in sequence:
if isinstance(item, int):
if item >= 0:
macropad.keyboard.press(item)
else:
macropad.keyboard.release(-item)
else:
macropad.keyboard_layout.write(item)
else:
# Release any still-pressed modifier keys
if isinstance(item, int) and item >= 0:
macropad.keyboard.release(item)
macropad.pixels[key_number] = apps[app_index].macros[key_number][0]
and the Windows Edge Macro, which sits in the macros folder per the project instructions.
# MACROPAD Hotkeys example: Microsoft Edge web browser for Windows
from adafruit_hid.keycode import Keycode # REQUIRED if using Keycode.* values
app = { # REQUIRED dict, must be named 'app'
'name' : 'Windows Edge', # Application name
'macros' : [ # List of button macros...
# COLOR LABEL KEY SEQUENCE
# 1st row ----------
(0x004000, '< Back', [Keycode.ALT, Keycode.LEFT_ARROW]),
(0x004000, 'Fwd >', [Keycode.ALT, Keycode.RIGHT_ARROW]),
(0x400000, 'Up', [Keycode.SHIFT, ' ']), # Scroll up
# 2nd row ----------
(0x202000, '- Size', [Keycode.CONTROL, Keycode.KEYPAD_MINUS]),
(0x202000, 'Size +', [Keycode.CONTROL, Keycode.KEYPAD_PLUS]),
(0x400000, 'Down', ' '), # Scroll down
# 3rd row ----------
(0x000040, 'Reload', [Keycode.CONTROL, 'r']),
(0x000040, 'Home', [Keycode.ALT, Keycode.HOME]),
(0x000040, 'Private', [Keycode.CONTROL, 'N']),
# 4th row ----------
(0x000000, 'Ada', [Keycode.CONTROL, 'n', -Keycode.COMMAND,
'www.adafruit.com\n']), # Adafruit in new window
(0x800000, 'Digi', [Keycode.CONTROL, 'n', -Keycode.COMMAND,
'www.digikey.com\n']), # Digi-Key in new window
(0x101010, 'Hacks', [Keycode.CONTROL, 'n', -Keycode.COMMAND,
'www.hackaday.com\n']), # Hack-a-Day in new win
# Encoder button ---
(0x000000, '', [Keycode.CONTROL, 'w']) # Close tab
as I said in my original post, the macropad works. I can send key commands to perform functions and shortcuts, but I can't sent plain text. In the code above for Edge, I'd have to change
to
(0x000040, 'Private', [Keycode.CONTROL, Keycode.SHIFT, Keycode.N]),
to get a new, private window in either Edge or Chrome. But I can't send something like "test sentence"
Hope this is clear.
