WEB page from SD Card on RP2040
by blakebr on Sun Sep 19, 2021 2:37 pm
I am trying to display web pages that are stored on an SD card connected to an RP2040 with WiFi.
I can store data to the SD card just fine.
I can get to a web page in 'http://192.168.1.188'. It displays 'index.html' that is in the '/static folder' just fine
It has a link to 'http://192.168.1.188/SD_CARD/index.html' and 'http://192.168.1.188/SD_CARD/' They both display 'This page isn't working'
If I stick the SD card into my PC the index.html on the SD Card loads fine and links to others on the SD card just fine.
I tried storing data from code.py into '/static/foobar.html', but that is not allowed. When I try I get a 'Write Protected" error.
What magic must I invoke to make this happen?
Must I mount the SD_CARD to the /root/ directory in a way that I can write to it and read from it as a web pages?
Should I be referencing SD_CARD by a different name?
Bruce
blakebr
Re: WEB page from SD Card on RP2040
by mikeysklar on Mon Sep 20, 2021 1:30 pm
Bruce,
Can you post some of the code in CODE brackets that you are using for on the RP2040?
mikeysklar
by blakebr on Mon Sep 20, 2021 2:28 pm
Hello Mikey,
Thank you for responding.
This is how I define where to write the files.
    try:
        SD_CS   = board.D2 # Use any pin that is not taken by SPI
        SD_CARD = "/SD_CARD"
        # Connect to the card and mount the filesystem.
        spi     = busio.SPI(board.SCK, board.MOSI, board.MISO)
        cs      = digitalio.DigitalInOut(SD_CS)
        sdcard  = adafruit_sdcard.SDCard(spi, cs)
        vfs     = storage.VfsFat(sdcard)
        storage.mount(vfs, SD_CARD)
    except:
        print("***************************** Exception Rebbot *****************************")
        print("Failed to configure for SD Card")
        time.sleep(10)
        supervisor.reload()
This is a quick test I ran to write to the /static subdirectory in the root directory of the RP2040.
The two comment lines are what I get on the serial console.
I thought if I could write to /static I would have a solution. Nope, write protected.
    file = open("/static/test.txt", "w")
    file.write("Hello World!")
    file.close
#    File "code.py", line 133, in <module>
#    OSError: [Errno 30] Read-only filesystem
This is the code that writes the local weather of the ZIP code retrieved from OpenWeatherMap.com.
SD_CARD is set to the path to the SD card. 26 weather forecasts by ZIP code are written to 26 different files.
def store_to_SD_card():
    file_name = (SD_CARD + "/" + ZIP + ".html")
    print("File Name: " + file_name)
    try:
        with open(file_name, 'w') as file: # a=append, w=write
            file.write("<html>")
            file.write("<br>")
            file.write("System  Time: {}/{}/{} at {}:{}:{} UTC\r\n".format(now.tm_mon,now.tm_mday,now.tm_year,now.tm_hour,now.tm_min,now.tm_sec))
            file.write("<br>")
            file.write(city_name + ", " + ZIP + "\r\n")
            file.write("<br>")
            file.write(main_text + ", " + description + "\r\n")
            file.write("<br>")
            file.write("%.2f\t Kelvin\r\n" % tempK)
            file.write("<br>")
            file.write("%.3f\t°Celsius\r\n" % tempC)
            file.write("<br>")
            file.write("%.3f\t°Celcius    - Dew Point \r\n" % DewPoint)
            file.write("<br>")
            file.write("%.3f\t°Celcius    - Feels Like\r\n" % Feel)
            file.write("<br>")
            file.write("%.3f\t°Fahrenheit\r\n" % tempF)
            file.write("<br>")
            file.write("%.3f\t°Fahrenheit - Dew Point \r\n" % CtoF(DewPoint))
            file.write("<br>")
            file.write("%.3f\t°Fahrenheit - Feels Like\r\n" % CtoF(Feel))
            file.write("<br>")
            file.write("%d\t Millibars\r\n" % Pres)
            file.write("<br>")
            file.write("%d%%\t Humidity\r\n" % Humi)
            file.write("</html>")
            file.close()
    except:
        print("Failed to open file on SD Card")
        supervisor.reload()
This is how I setup the web server.
wsgiServer = server.WSGIServer(80, application=web_app)
print("open this IP in your browser: ", esp.pretty_ip(esp.ip_address))
This is the 'index.html' file has been written to '/static'. It displays just fine when I open Chrome to 192.168.1.188. When I click either link, disappointment.
<html>
Hello<br>
Hello<br>
<br> <font size=+2><a href="/SD_CARD/index.html">Weather</a></font><br><br>
<br> <font size=+2><a href="/SD_CARD/">Weather</a></font><br><br>
Hello<br>
Hello<br>
</html>
What am I missing?
Thanks for looking at my code.
Bruce
blakebr
by mikeysklar on Tue Sep 21, 2021 1:15 pm
Bruce,
I'm hoping this will be as simple as a relative path issue.
Does it help at all if you only reference index.html without a full path from /SDCARD.
<br> <font size=+2><a href="index.html">Weather</a></font><br><br>
<br> <font size=+2><a href="./index.html">Weather</a></font><br><br>
mikeysklar
by blakebr on Tue Sep 21, 2021 6:32 pm
Mike,
Thanks for your reply.
I tried the index.html given below. Only #5 and #7 worked, but they took me back to the original index.html file. None took me to the index.html file that is on the SD Card.
What this tells me is that the index.html is being properly sent to the browser, and it is able to interpret it.
What we don.t know is if the SD Card is mounted to the /root/ or / directory or someplace else. Where that 'else' is, is a mystery.
<html>
<center>
Hello<br>
<br> <font size=+2><a href="/SD_CARD/index.html">Weather 1</a></font><br><br>
<br> <font size=+2><a href="/SD_CARD/">Weather 2</a></font><br><br>
<br>
<br> <font size=+2><a href="./SD_CARD/index.html">Weather 3</a></font><br><br>
<br> <font size=+2><a href="./SD_CARD/">Weather 4</a></font><br><br>
<br>
<br> <font size=+2><a href="./index.html">Weather 5</a></font><br><br>
<br> <font size=+2><a href="./SD_CARD/">Weather 6</a></font><br><br>
<br>
<br> <font size=+2><a href="../index.html">Weather 7</a></font><br><br>
<br> <font size=+2><a href="../SD_CARD/">Weather 8</a></font><br><br>
Hello<br>
</center>
</html>
blakebr
by mikeysklar on Tue Sep 21, 2021 7:27 pm
Since #5 worked maybe it does not matter so much about where the index.html is located, but that all you can see is the current folder that the index.html is located in. If you avoid adding a full path names you should be able to access index.html and any sub-folder content without issue.
mikeysklar
by blakebr on Tue Sep 21, 2021 7:40 pm
The code below behaves the same as #5 and #7. It shows the index.html in /static.
<br> <font size=+2><a href="index.html">Weather 9</a></font><br><br>
blakebr
by blakebr on Tue Sep 21, 2021 8:07 pm
Mike,
After I understand what is said; in "CircuitPython Storage" I may have found the answer.
It looks like I must also have a "boot.py" file on CIRCUITPY that looks at a data pin and makes CURCUITPY writable by either the computer or code.py but not both.
I would need to create a boot.py file that with no jumper grounding the data pin I could write and edit code. With the data pin pulled high I could write to the CIRCUITPY file system but not be able to edit code.
The examples do not explicitly mention the RP2040 so I would need to play with a microcontroller that I can afford to corrupt and use the wipe routines on it.
Bruce
blakebr
by blakebr on Wed Sep 22, 2021 7:17 pm
Mike,
After a lot of fits-and-starts I finally got it working. The "CircuitPython Storage page may need to be to be updated.
It does not account for the Raspberry Pi Pico, or the Nano RP2040 Connect. Probably other RP2040 platforms.
There is still one issue. The data written to the system memory is not made available when the file is closed. I have the following at the end of writing the data structure.
            file.write("<br>")
            file.flush()
            time.sleep(0.05)
            file.close()
It becomes available if I do a button reset, a Ctrl-C, Ctrl-D reboot, or remove power. Is there a way to remove this data block?
Bruce
blakebr
by blakebr on Thu Sep 23, 2021 11:04 am
Mike,
I let the project run overnight. Without me touching anything the files were updated at 00:57:35 UTC and then again at 09:57:33 UTC. I live in the -4:00 time zone so current weather that is 5 to 6 hours old is not current.
The only solution I have thought of is to have the project reboot after each cycle of 26 locations, or on the hour, or.... That solution sucks.
Bruce
blakebr
by mikeysklar on Thu Sep 23, 2021 5:13 pm
Bruce,
Good work getting things this far.
Now since the controller seems to be locking up roughly every day maybe we can work on that.
Let's start with making sure you are running CircuitPython 7 with the current libs.
Which model of RP2040 are you using Feather / Pico / QtPy etc.?
mikeysklar
by blakebr on Thu Sep 23, 2021 6:04 pm
Mike,
I am running 7.0.0, see boot_out.txt below. The 'boot.py Finis' is my add to tell boot.py finished.
Adafruit CircuitPython 7.0.0 on 2021-09-20; Arduino Nano RP2040 Connect with rp2040
Board ID:arduino_nano_rp2040_connect
boot.py output:
   boot.py Finis
I am running this on a Feather with AirLift, and Nano Connect. As far as my needs they are functionally equivalent.
IMHO, There is an issue between when data is written to a buffer for the flash memory and when it is written to the actual flash memory. I thought file.close() would flush the buffer. When that didn't, I added file.flush() to force a flush. That didn't work.
The fact that the buffer is written to the flash memory at some interval indicates that it is being done. I just need to know how to trigger that magic function without pushing the RESET button or disrupting power.
Bruce
blakebr
by mikeysklar on Thu Sep 23, 2021 8:49 pm
Bruce,
The Feather board + Airlift you are using. Is that also connected to a PC?
There is some discussion in one of our CircuitPython github repo on issue# 111 about FAT12 filesystems not flushing.
https://github.com/adafruit/circuitpython/issues/111
It also looks like there are some things to try:
1) bootloader update
2) 'sync' from a linux machine
3) autoreset.
add to boot.py
 import samd
samd.disable_autoreset()
print("*** Disabling auto-reset.")
mikeysklar
by blakebr on Thu Sep 23, 2021 11:02 pm
Mike,
The #111 issue looks to be an editor corrupting the file system by making partial writes or something. The file system is not corrupted on my machines.
I get the delayed writes to the flash memory from code.py when I am connected to my windows 10 PC as when I am connected to a 60 watt power supply.
I will add the text you suggested tomorrow. It is 11 PM here in Maryland. Time to turn the brain off and go unconscious for a while.
Thank you for all your help.
Bruce
blakebr
by blakebr on Thu Sep 23, 2021 11:12 pm
Mike,
3) autoreset.
1) How do I update the bootloader? Which bootloader are you referencing, the RP2040 or the AirLift?
2) ‘sync’ what from a Linux machine? I only have Raspberry Pi Linux machines.
3) I will test the autoreset code tomorrow.
Bruce
blakebr
