digitalio blink confusion
RoseNose
Post by RoseNose »
I'm sure I'll feel like a real idiot when I figure this out, but I'm not sure what I'm seeing. I'm trying to make a basic blink using an n-channel transistor and some 5v 1a leds in parallel. I can force them to blink just fine in the REPL, so this isn't a wiring question. This is my (stripped down for testing) code:
import time
import board
import digitalio
mosfet_pin = digitalio.DigitalInOut(board.D0)
mosfet_pin.direction = digitalio.Direction.OUTPUT
mosfet_pin.value = False
while True:
    print(mosfet_pin.value)
    mosfet_pin.value = not mosfet_pin.value
    print(mosfet_pin.value, "\n")
    time.sleep(1)
In the terminal I see
False
False
False
False
But the light stays on. I'm very confused. From what I can see, the mosfet_pin.value is never True, but the light stays on the whole time and doesn't blink. Can anybody enlighten me on what I've done wrong, and a way I could troubleshoot a problem like this on my own moving forward?
Ps. Further weirdness. I ran the code line by line in the REPL.
Adafruit CircuitPython 7.0.0 on 2021-09-20; Adafruit QT Py RP2040 with rp2040
>>> import board
>>> import digitalio
>>> mosfet_pin.value = not mosfet_pin.value # LED ON
>>> mosfet_pin.value = not mosfet_pin.value # LED OFF
>>> print(mosfet_pin.value)                               # LED ON
False        # LED ON
>>> mosfet_pin.value = not mosfet_pin.value # LED STILL ON
It works fine blinking the light *up until* I print. Once I print the state of the value the light stops blinking and stays on while I only get False as the read value.
dastels
Re: digitalio blink confusion
Post by dastels »
What happens if you take the prints out of the non-REPL code?
