I am building your diy-air-quality-monitor project and am in the section called "connect to wifi". I am using BANNED 7.0.0 and the examples set 7.x (This zip was downloaded from https://learn.adafruit.com/adafruit-air ... et-connect on September 21, 2021). When trying to run the code, I get the following error:
code.py output:
ESP32 SPI webclient test
File "code.py", line 50, in <module>
File "adafruit_esp32spi/adafruit_esp32spi.py", line 335, in status
File "adafruit_esp32spi/adafruit_esp32spi.py", line 324, in _send_command_get_response
File "adafruit_esp32spi/adafruit_esp32spi.py", line 238, in _send_command
RuntimeError: ESP32 timed out on SPI select
I can't seem to get past this point. Could you please help me with this
circuitpython DIY air quality monitor problem
- adafruit_support_carter
Re: circuitpython DIY air quality monitor problem
Did you download the zip using the Download Project Bundle button?
- RoyBob
Yes I did download the bundle and moved the files to the circuitpy folder. I have just repeated the procedure, and received the same error message.
Is your hardware setup the same as the air quality guide? Feather M4 Express + AirLift FeatherWing? (or, if not, what?) We'll try and duplicate the error here, matching your setup.
- RoyBob
Yes, my hardware setup is the same as the air quality guide with the exception of the "FeatherWing Doubler board" which was unavailable at the time. I used 2 "FeatherWing Proto boards" with the 3v and ground connected, and checked with a voltmeter.
- RoyBob
I have managed to purchase a "FeatherWing Doubler board" , and I no longer receive he error when running the code. Thanks for the help.
Sorry for not responding on your other post. It was probably something with your use of the proto boards on the other setup. But glad it's working now with the doubler.
