REPL says Adafruit CircuitPython 7.0.0-rc.1 on 2021-09-02 Adafruit MagTag with ESP32S2
import board
dir(board)
it does not display RX, TX, or UART
What am I doing wrong?
Magtag board does not have RX, TX, or UART
- dastels
Re: Magtag board does not have RX, TX, or UART
The Tx/Rx connections are for debugging the ESP32-S2. It is not exposed in the board module.
- planxty312
darn. Any good way to connect to a RS232 device?
- dastels
You might be able to repurpose the I2C interface to be a UART. There's also the D10 and A1 connections. You might be able to use them as a software (i.e. bit-banged) serial connection.
- tannewt
You should be able to initialize a `busio.UART` with any of the exposed pins. The ESP32-S2 allows you to route any pin to most internal peripherals (like UART.)
`board` is only showing you names that are present on the physical board. You don't have to stick to those uses. :-)
- Gradymo
This worked for me. I hooked up an ultimate GPS, which speaks serial, to the stemma-Qt port like so:
uart = busio.UART(board.SCL, board.SDA, baudrate=9600, timeout=10)
- kevinjwalters
One thing worth mentioning is a serial connection with an Adafruit MagTag is going to output "TTL" UART at 3.3/0V (not 5/0V) which is a rather different thing to RS232 ~ -12V/+12V. There's a discussion of this on: StackExchange: Electrical Engineering: Difference between UART and RS-232?.
- dastels
Traditionally, TTL meant 5v. So an Arduino UNO UART is TTL serial. Magtag UART is 3.3v. A more general term would be "logic level" serial vs. RS-232 serial. You can use a MAX232 chip from Maxim to do the conversion between 5v serial and RS232. Maxim also has version of the chip that works with 3.3v.
