Hi, i need precise motor controll and so i build something with the geared dc motor with build in encoder (N20 DC Motor with Magnetic Encoder), i connected it to the raspberry pi using the motor bonnet from adafruit and got it running using circuitpython on the raspberry zero.
Sadly i have 2 issues, first, i need usb controll and raspberry gadget mode is to cumbersome in practice
secondly, rotaryio is not supported on the raspberry circuitpython, so no easy encoder use.
So i want to use the hardware i have on the pi pico, should be much easyer. According to the scematics the motor bonnet only uses the i2c interface. So i just need to connect that and power to the pico,
QUESTION:
Does Circuidpython on the pi pico support the adafruit motor bonnet via i2c ??
motor bonnet on pi pico
- dastels
Re: motor bonnet on pi pico
It should. The bonnet uses just I2C.
- fredmf
confirmed, does work, needed to solder 2 4.7k resistors between sda - 3v3 and scl - 3v3
