Flash Micropython to Pyportal Pynt
dougconran
Post by dougconran »
I have a Pyportal Pynt running Circuitpython 7.0.0. Is it possible to flash this with Mircopython? Currently, when I try to do this I get the following error message :-
>python esptool.py --chip esp32 --port COM6 erase_flash
esptool.py v3.2-dev
Serial port COM6
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
when trying to do the initial erase. I am running the command with Administrator privileges and have confirmed that the device is on serial COM6
danhalbert
Re: Flash Micropython to Pyportal Pynt
Post by danhalbert »
The PyPortal Pynt is a SAMD51 board with an ESP32 co-processor. It will not run the MicroPython ESP32 code.
