Got 2 Mini 1.3inch 240x240
One is working and second one is not working
Attached the picture which shows working and not working unit. Both were added to same RaspBerry PI Zero W unit (obvious after shutdown)
Thanks and Regards
Sarang
Mini TFT 240x240
- stirucherai
Mini TFT 240x240
- Attachments
- MinTFT.jpg (40.12 KiB) Viewed 128 times
- adafruit_support_carter
Re: Mini TFT 240x240
Does anything show up in an I2C scan?
https://learn.adafruit.com/scanning-i2c ... spberry-pi
- stirucherai
This minTFT 240X240 is spi based right any case out of i2cdetect
pi@BDLThirucherai:/var/www/html $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
pi@BDLThirucherai:~ $ sudo python3 blinka.py
Hello blinka!
Digital IO ok!
I2C ok!
SPI ok!
done!
Please note for the working unit also the output is same. As mentioned earlier the base unit was same (with same OS install of micro SD card )
Hello blinka!
Digital IO ok!
I2C ok!
SPI ok!
done!
facepalm. indeed it is. sorry.This minTFT 240X240 is spi based right any case out of i2cdetect
Can you post a photo of the backside of the problematic TFT, similar to this view:
https://cdn-shop.adafruit.com/970x728/4484-02.jpg
- stirucherai
Photo Attached
- Attachments
- MiniTFT_NOTWorkingUnit.jpeg (127.84 KiB) Viewed 109 times
Thanks for the photo. There's a chance maybe the ribbon cable is not fully inserted? Worth trying at least. Do this unpowered. Push the little black retainer tabs (arrow) out to release, then push the ribbon cable in snuggly, and then push the retainer tabs back in.
You can use your other TFT for comparison. The product photo also appears much more inserted:
OK. Thanks for trying. Let's replace it.
Send an email to [email protected] with a link to this thread and your order number and they can send you a replacement Mini TFT.
