Hi!,
I'm going through the learn guide for the APDS9960 Proximity, Color, Gesture sensor preparing examples for class. I notice on the CircuitPython example page:
https://learn.adafruit.com/adafruit-apd ... cuitpython
the guide refers to
I notice the guide refers to the the proximity() function function as:
sensor.proximity()
When I try to use this I get an error:
TypeError: 'int' object is not callable
However when I stop using this as a method & remove the parentheses like this:
sensor.proximity
things work fine. I'm using CircuitPython 7.0 on an Arduino Nano RP2040 Connect with STEMMA-QT cable hooked to the board via breadboard.
Wanted to point this out if there was a problem with the guide, but also I want to be corrected if I'm missing something.
John
APDS9960 learn guide & .proximity()
- kattni
Re: APDS9960 learn guide & .proximity()
You are correct! The library was updated a while back and the behavior changed from the guide, and the guide was never updated. We're in the process of updating it now.
Thanks for letting us know!
