I'm using a Feather M4 Express to control an ePaper display (epd) and an Airlift wifi board (esp32)... an IOT project. I've wired up the boards and can run a program for the display successfully and a separate program for the wifi successfully. Now I'm trying to marry the two programs so I can display stuff from the internet.
I understand I need to use the Chip Select CS part of SPI to turn the EPD and ESP high and low depending on when they are needed. However, I'm having trouble with the pin set up and SPI bus set up in the code. I've copied the first part of my program below which is throwing the error. I'm getting the error message "type error: expect a Pin" referencing the last line of code below (displaly_bus =....). Thanks in advance for your assistance.
# IMPORT MODULES
import board
import busio
import digitalio
import displayio
from digitalio import DigitalInOut
import adafruit_requests as requests
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
from adafruit_esp32spi import adafruit_esp32spi
from secrets import secrets
import time
import adafruit_il0373
import terminalio
from adafruit_display_text import label
from adafruit_display_shapes.line import Line
# DEFINE VARIABLES
epd_dc = board.D10
epd_cs = digitalio.DigitalInOut(board.D9)
epd_cs.direction = digitalio.Direction.OUTPUT
epd_cs.value = True
# If you have an AirLift Shield:
esp32_cs = digitalio.DigitalInOut(board.A5)
esp32_cs.direction = digitalio.Direction.OUTPUT
esp32_cs.value = False
esp32_ready = DigitalInOut(board.A4)
esp32_reset = DigitalInOut(board.A3)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
displayio.release_displays()
display_bus = displayio.FourWire(
spi, command=epd_dc, chip_select=epd_cs, baudrate=1000000)
