Sunday, October 17th
I need some help on this project I have created.
I am using a Pi Zero W set up for CircuitPython.
I am using i2C connected to the following Adafruit sensors: MS8607 and PMSA003I.
I have attached a photo of the components, the CircuitPython code, and the full error print out.
When I run the code, it will run for 2 to 8 hours, and then has an error(s). It prints out everything just fine and sends sensor values to Adafruit io just fine until a dreaded error occurs.
The error(s) is a direct result of the CircuitPython connection to Adafruit io. So the CircuitPython code from lines 168 to 205 are the main concern.
I have tried tweaking the code so many times, I am about to give up.
I have had great success running similar CircuitPython code and various sensors sending information to Adafruit io that will run for days and days with no errors. I have used very successfully the PyPortal and the Feather RP2040 with the AirLift WiFi FeatherWing connected to different sensors. After some tweaking, they now work error for days and days.
I have pretty much followed Brent Rubell’s CircuitPython code using his example of sending analog sensor values to an Adafruit IO feed. See a note at the beginning of the code.
I am looking for ideas/suggestions on how to catch errors and do something to keep the code running.
Hope someone can help out.
Tom Henry
Pi Zero W, various Adafruit Sensors and Adafruit io
- Tom_Henry
- PI Zero Tom Henry.pdf
- (222.88 KiB) Downloaded 4 times
- PiSensors2.py
- (6.2 KiB) Downloaded 4 times
- Pi.txt
- (3.8 KiB) Downloaded 3 times
- adafruit_support_carter
Re: Pi Zero W, various Adafruit Sensors and Adafruit io
Were all of these projects running on the same wifi network? In general, it looks like some kind of temporary network issue:
socket.gaierror: [Errno -3] Temporary failure in name resolution
- Tom_Henry
Yes, the Raspberry Pi Zero W was connected to our home WiFi network.
And the Raspberry Pi Zero W was connected to the PMSA003I, the MS8607, and the PCF8523 as you see in the photo.
What does "Temporary Failure in Name Resolution" mean?
Tom Henry
Tom Henry
- Tom_Henry
Monday evening
Additional notes and comments:
Your comments and questions:
What doesn’t make sense here is I am running several other Adafruit devices running CircuitPython with multiple sensors. I have attached 3 screenshots showing results from Adafruit’s Metro ESP32-S2, Adafruit’s PyPortal with a multitude of Adafruit sensors, and Adafruit’s Feather RP2040 with the AirLift WiFi FeatherWing Coprocessor. All of these devices are on at the same time as the Raspberry Pi Zero W with Adafruit’s PMSA003I and MS8607.
All of Adafruit’s CircuitPython devices are currently running error free for days and days.
Only the Raspberry Pi Zero W running CircuitPython is the problem that keeps crashing. I am beginning to believer that the Raspberry Pi and CircuitPython don’t work well together. The Raspberry Pi will crash consistently within an hour or two.
I am ready to be proven wrong. I do like using a Raspberry Pi and Adafruit io because I can access the Pi via VNC and restart, stop, make changes remotely. I can’t do that with any of the above Adafruit devices. Whether you are running Arduino or CircuitPython, they are both the same. Turn the device on and it runs a program called something like code.py.
I really like the ease of use of Adafruit io once I figured out how to use it.
So, how can we fix the code for the Raspberry Pi so it will not crash every hour or so? I am open to any and all suggestions.
Thank you,
Tom Henry
Thank you,
Tom Henry
- PyPortal Dashboard.png (150.03 KiB) Viewed 121 times
- Metro ESP32-S2 .png (145.88 KiB) Viewed 121 times
- Feather RP2040 AirLift WiFi.png (104.04 KiB) Viewed 121 times
