jetson docker image not seeing librarys
famil
Post by famil »
i am trying to use the getting started jetson tutorial so i and the container example that includes juypter i have got the circuit-python kernal for juypter install and added the adafruit-blinka put tit can't find any of the library's
i did get it to work outside of the contianer with the python script you supply but can't figure how to install juypter on the jenson.
famil
Re: jetson docker image not seeing librarys
Post by famil »
HI
Have gotten Jupyter lab installed outside of a container. I installed Jupyter lab using these instructions install https://medium.com/swlh/the-newbie-guid ... 0449346258.
i can run blinktest.py from termail and it works. I ran it from jupyter on the jetson and it says circuitpython vm: found no board.
Do i have to connect another computer to the jetson thorugh usb or can i use ssh to see the board
