Free ram decrease in every cycle
Bobricius
Post by Bobricius »
Hi I have stupid beginner question, I try display free ram, but it quickly decrease in cycle to zero and then to max, is it normal????
https://youtu.be/OLCY_EU78bo
while True:
	text =  "Free ram:"+str(gc.mem_free())
	text_area = label.Label(terminalio.FONT, text=text, scale=3)
	text_area.x = 10
	text_area.y = 10
	#time.sleep(1)
	display.show(text_area)
dastels
Re: Free ram decrease in every cycle
Post by dastels »
In short, yes.
When you do things that allocate objects (like crating that Label) or otherwise consume memory it takes it from the free memory. The amount of free memory will decrease over time if you wantonly use memory (there are ways to minimize that). When it gets below a certain amount (or some other criteria... I'm not sure what exactly CircuitPython uses) the garbage collector executes and tidies up, reclaiming memory that isn't being used any more.
adafruit2
Post by adafruit2 »
you probably want to create the label once, then change the text whenever the value to display changes
