HalloWIng M4 Express is not working
dritmy
Post by dritmy »
Hello!
I ordered my Hallowing M4 in March 2020. It remained unopened until today.
When I connected it to my Macbook and turned it on, a Spooky Eye screensaver did not appear.
Yellow charge LED blinks like a stroboscope.
Red #13 LED slightly fades 3 times in a second.
Four sides RGB's constantly lights in red.
Double bush on Reset button has no effect.
Long push on Reset button only switches off #13 LED.
The device itself is not shown in Finder (like USB storage or something else).
Do you have any suggestions on how to fix that?
dritmy
Re: HalloWIng M4 Express is not working
Post by dritmy »
Short update:
I connected board to my old Mac (mid 2012).
Now I can see HALLOWING device and 3 files inside.
RGBs are green now.
There are 3 files inside (see screenshoot).
INFO_UF2.TXT content:
UF2 Bootloader v1.23.1-adafruit.1-210-g795abd2 SFHWRO
Model: HalloWing M4
Board-ID: SAMD51J19A-HalloM4-v0
photo_2021-10-25 15.48.57.jpeg (13.09 KiB) Viewed 133 times
adafruit_support_carter
Are you seeing a folder named HALLOM4BOOT?
dritmy
Post by dritmy »
HALLOM4BOOT appears like a 'device'. Content of that device (folder) you can see on the screenshot. But I can see that only on my old Mac (mid 2012, El Capitan)
photo_2021-10-26 08.45.47.jpeg (42.63 KiB) Viewed 117 times
dritmy
Post by dritmy »
I think that topic can be closed.
I installed the latest UF2 bootloader and M4 EYES Firmware. Now it works as expected. Strange that it was not working initially. However, the documentation says: "The HalloWing M4 board should arrive ready-to-scare. Connect a battery or USB cable, move the power switch to the “on” position, and after a few seconds you should get a blinking eye"
Sorry, if added a topic with such a stupid problem)
No worries. Just glad it's working. It may be that back in 2020 they were shipping with different out of the box setup? Not sure. But at least it's all working now. Have fun!
