SerialESPPassthrough ESP32 Airlift doesn't echo
richardf
Post by richardf »
I hook up my processor (Teensy) to Adafruit AirLift.
I can connect and interact with server.
My problem is SerialESPPassthrough doesn't echo back the data I send it from Serial1.
On startup, Teensy Serial1 receives text report from AirLift (e.g., rst:0x1 (POWERON_RESET),boot:0x12
yet, when I enter data to Teensy through Serial Monitor, the AirLift does not echo this data back.
I have tried on two systems so I know the wiring is correct and processors function.
  #define SerialESP32   Serial1
  #define SPIWIFI       SPI  // The SPI port
// my wiring
  #define SPIWIFI_SS     10   // Chip select pin
  #define ESP32_RESETN   41   // Reset pin
  #define SPIWIFI_ACK    9   // a.k.a BUSY or READY pin
  #define ESP32_GPIO0   40
I have Serial 1 wired
Teensy pin 0 (rx1) to TXO
Teensy pin 1 (tx1) to RXI
I receive chars entered from Serial Monitor and send them to the Airlift; however, outside of during boot, no chars come back from the AirLift.
// send data to AirLift
  while (Serial.available()) {
      char c = Serial.read();
      Serial.println(c);
     SerialESP32.write();
  // get data from AirLift
  while (SerialESP32.available()) {  // BESIDES BOOT, NO DATA AVAILABLE
    Serial.write(SerialESP32.read());
This indicates to me that the AirLift is not handling data on its RXI pin. Any suggestions?
thanks,
Richie
mikeysklar
Re: SerialESPPassthrough ESP32 Airlift doesn't echo
Post by mikeysklar »
Hi Richie,
Which model of the Airlift are you using with your Teensy? Is it the FeatherWing or Breakout board?
Can you post the full code and a photo of your setup?
richardf
Post by richardf »
esp serial tester schematic.jpg (1009.9 KiB) Viewed 247 times
esp serial tester photo.jpg (995.57 KiB) Viewed 247 times
On power-on reset esp sends. This indicates the Tx0 is functioning:
etsJul29201912:21:46 rst:0x1(POWERON_RESET),boot:0x2(D
Typing“abcd” reports:
Serial sent:a
Serial sent:b
Serial sent:c
Serial sent:d
Serial sent:<10>
Yet esp does not send any response. I have double checked each wire and have tried software
on two identical units so I am confident wiring is correct.
I can connect to internet and download/upload data to my web site database using these units.
I just can't get SerialESPPassthrough to work.
Source code running on Teensy 4.1 taken from SerialESPPassthrough.ino:
unsigned long baud = 115200;
#define ESP32_GPIO0 39
void setup()
Serial.begin(baud);
while (!Serial);
delay(1000);
SerialESP32.begin(baud);
pinMode(SPIWIFI_SS, OUTPUT);
pinMode(ESP32_GPIO0, OUTPUT);
pinMode(ESP32_RESETN, OUTPUT);
// manually put the ESP32 in upload mode
digitalWrite(ESP32_GPIO0, LOW);
digitalWrite(ESP32_RESETN, LOW);
delay(100);
digitalWrite(ESP32_RESETN, HIGH);
delay(100);
char c;
c = Serial.read();
SerialESP32.write(c);
if (c==10) Serial.printf("Serial sent:<10>\n");
else Serial.printf("Serial sent:%c\n",c);
c = SerialESP32.read();
Serial.println(c);
// Serial.printf("esp sent:%d = %c\n",SerialESP32.available(),c);
mikeysklar
I understand the issue.
The RXI and TX0 pins on the AirLift breakout are for uploading new firmware and using in bluetooth mode. These pins are to be left disconnected in WiFi mode.
RXI & TXO - Serial data in and Serial data out, used for bootloading new firmware, and for communication when in BLE mode. Leave disconnected if not using BLE or when not uploading new WiFi firmware to the AirLift (which is a rare occurrence).
https://learn.adafruit.com/adafruit-air ... ut/pinouts
Screen Shot 2021-11-29 at 2.45.57 PM.png (378.02 KiB) Viewed 223 times
richardf
Post by richardf »
thanks but your response makes no sense.
You are correct that in Wifi mode, the Serial TXo and Rxi have no effect.
My Wifi mode works fine without the Serial TXo and Rxi .
However, in order to program the device using SerialESPPassthrough, you MUST
use these serial lines as shown in the description.
RIchard
mikeysklar
I agree with you that RXi and TXo are used for updating the bootloader on the AirLift ESP32 breakout.
The guide suggests changing the pinouts to match your variant. Have you tried using the TEENSYDUINO pins?
#elif defined(TEENSYDUINO)
  #define SPIWIFI_SS     5   // Chip select pin
  #define ESP32_RESETN   6   // Reset pin
  #define ESP32_GPIO0   -1
  #define NEOPIXEL_PIN   8
Are you actually trying to upgrade the nina-fw?
richardf
Post by richardf »
My pins, as seen in my source code and schematic reflect the teensy pins. Trying to update certificate and maybe utilize Bluetooth. I know airlift transmits data to teensy across Serial1. Either teensy output on serial1 not received properly It is wired correctly. Or airlift not responding to teensy output as expected.
mikeysklar
@richardf,
I see two options.
1) You can try the recommended pinouts we define for the Teensy 4.0/4.1. This was added to the code in August 2020.
https://github.com/adafruit/WiFiNINA/pull/4
2) You can try not using our library. This one has explicit support for the Airlift breakout and Teensy 4.1. It might help with certificate upload.
https://github.com/khoih-prog/WiFiNINA_Generic
