how can I clear the display so it only shows black again? I use the adafruit_displayio_ssd1306.SSD1306 lib.
When I use sleep and wake the last content is shown again. Also, fill(0) doesn't work.
Any tips on how to reset the content?
Clear display ssd1306
- rpiloverbd
Re: Clear display ssd1306
I used Adafruit_GFX.h and Adafruit_SSD1306.h whenever I worked with SSD1306 OLED display and arduino. I used the clearDisplay(); function to clear the display.
- adafruit_support_carter
You'll need to do this via displayio. That are various ways and it depends on what you are trying to do. What is the current code you are using to drive the display?
- Old_novice
void OLED_clear()
OLED_send(SSD1306_SET_PAGE_ADDR); // 0x22
OLED_send(0); // start at row top
OLED_send(7); // end at the bottom row
OLED_sendCommand(SSD1306_SET_COLUMN_ADDR); // opcode:0x21
OLED_sendCommand(0); // start at left edge of screen
OLED_sendCommand(127); // end at right edge of screen
for (uint16_t scrClearIndex=0; scrClearIndex<1024; scrClearIndex++)
{ // (SSD1306_LCDWIDTH*SSD1306_LCDHEIGHT/8)
TWCR=((1<<TWINT)|(1<<TWSTA)|(1<<TWEN)); // send START
while(!(TWCR & (1 << TWINT))); // delay until TWINT set
TWDR = OLED_SLA7 << 1; // 8-bit SLAw = 0x78
TWCR = ((1<<TWINT)|(1<<TWEN));
while(!(TWCR & (1<<TWINT))); // TX?done delay
TWDR = 0x40; // send D/C_sentinal byte for data stream
for (uint8_t x=0; x<16; x++)
TWDR = 0x00; // all eight pixels in the column are off.
scrClearIndex++; // 16 bytes per I2C transmission__64 transmissions per screen
scrClearIndex--;
//TWCR = ( (1<<TWINT)|(1<<TWEN)|(1<<TWSTO) ); // I2C STOP
Last edited by adafruit_support_carter on Wed Dec 08, 2021 11:21 am, edited 1 time in total.
Reason: add [code] tags
- Old_novice
Using the rhe C code below, I can clear row zero but the other rows remain. It's obviously my coding but I can't see why.
void OLED_clear()
OLED_send(7); // end at row bottom
OLED_sendd(SSD1306_SET_COLUMN_ADDR); // opcode:0x21
OLED_send(0); // start at screen left edge
OLED_send(127); // end at screen right edge
while(!(TWCR & (1 << TWINT))); // wait for TWINT set
TWDR = OLED_SLA7 << 1; // 8-bit SL addr = 0x78
while(!(TWCR & (1<<TWINT))); // TX wait
TWDR = 0x00; // eight collumn pixels off
scrClearIndex++; // 16 bytes per I2C transmission x 64
scrClearIndex--;
- added [code] tags
- SSD1306.jpg (214.02 KiB) Viewed 121 times
