I2C cable to connect pyPortal to PMSA003I
bonemender
Post by bonemender »
I purchased the PyPortal, the PMSA003I and some JST SH 4-pin cables. The plugs fit the PSMA003I perfectly, but are too small for the PyPortal. Which cable should I get to connect the PyPortal to the PMSA003I?
danhalbert
Re: I2C cable to connect pyPortal to PMSA003I
Post by danhalbert »
You want a JST SH (small, usually black) to JST PH (larger, usually white) cable: https://www.adafruit.com/product/4424 (this one has both ends white).
Note also you want to change the jumper on that connector from 5V to 3.3V if you are going to connect I2C devices: https://learn.adafruit.com/adafruit-pyp ... 3020489-20
