Can anyone help me solve this:-
I've already given myself permissions ref: sudo usermod -a -G dialout <myUsername>
Here is the crash report:-
Something has gone wrong with Mu. Here's the error:
File "/usr/local/lib/python3.8/dist-packages/mu/app.py", line 159, in run
raise ex
File "/usr/local/lib/python3.8/dist-packages/mu/app.py", line 146, in run
venv.ensure_and_create(self.display_text)
File "/usr/local/lib/python3.8/dist-packages/mu/virtual_environment.py", line 621, in ensure_and_create
self.recreate()
File "/usr/local/lib/python3.8/dist-packages/mu/virtual_environment.py", line 566, in recreate
self.create()
File "/usr/local/lib/python3.8/dist-packages/mu/virtual_environment.py", line 768, in create
self.install_baseline_packages()
File "/usr/local/lib/python3.8/dist-packages/mu/virtual_environment.py", line 878, in install_baseline_packages
wheels.download(zipped_wheels_filepath, logger)
File "/usr/local/lib/python3.8/dist-packages/mu/wheels/__init__.py", line 194, in download
zip_wheels(zip_filepath, temp_dirpath, logger)
File "/usr/local/lib/python3.8/dist-packages/mu/wheels/__init__.py", line 165, in zip_wheels
with zipfile.ZipFile(zip_filepath, "w") as z:
File "/usr/lib/python3.8/zipfile.py", line 1251, in __init__
self.fp = io.open(file, filemode)
PermissionError: [Errno 13] Permission denied: '/usr/local/lib/python3.8/dist-packages/mu/wheels/1.1.0.beta.6.zip'
MU Installation On Linux Mint
- Franklin97355
Re: MU Installation On Linux Mint
Check out this article https://www.guru99.com/file-permissions.html#3
- danhalbert
How did you do the installation, and which version of Mu are you trying to install?
I just solved the problem. Another rookie mistake by me. I forgot to type sudo before mu-editor. Thanks very much for your help.
- danhalbert
You should not need the `sudo` if you have put yourself in the dialout group. However, you need to log out completely (rebooting is best) to make that take effect.
