Refresh problem eInk featherwing/circuitPython
artman70
Post by artman70 »
I have a featherS2 and a 2.9 grayscale featherwing.. i use the following code to set some text..
import time
import busio
import board
import displayio
import terminalio
import adafruit_il0373
from adafruit_display_text import label
displayio.release_displays()
spi = busio.SPI(board.SCK, board.MOSI)
epd_cs = board.IO1
epd_dc = board.IO3
display_bus = displayio.FourWire(
    spi, command=epd_dc, chip_select=epd_cs, baudrate=1000000
time.sleep(1)
display = adafruit_il0373.IL0373(
    display_bus,
    width=296,
    height=128,
    rotation=270,
    black_bits_inverted=True,
    color_bits_inverted=True,
    grayscale=True,
    refresh_time=1,
sampleTxt = "THIS IS A TEST"
textBox = label.Label(terminalio.FONT, text=sampleTxt, x=100,y=50, color=0xFFFFFF)
display.show(textBox)
display.refresh()
time.sleep(20)
textBox.text = "Testing Testing Testing"
display.refresh()
time.sleep(1)
the first text prints fine
but the second text input never prints on the display
im sure im using label wrong or refresh wrong but cant see how..
thank you for the help!!!
alpierce
Re: Refresh problem eInk featherwing/circuitPython
Post by alpierce »
If you are wishing to display different text in multiple areas of the display
Try adding a display group like:
screen = displayio.Group()
display.show(screen)
create the text areas:
fail_text = "PF 11/24/21 23:50:30"
fail_text_area = bitmap_label.Label(terminalio.FONT, text=fail_text, scale = 2, color=color )
fail_text_area.x = 5
fail_text_area.y = 30
restore_text = "PR 11/24/21 23:56:20"
restore_text_area = bitmap_label.Label(terminalio.FONT, text=restore_text, scale = 2, color=color )
restore_text_area.x = 5
restore_text_area.y = 60
duration_text = "PD 23Hrs 23Min 56Sec"
duration_text_area = bitmap_label.Label(terminalio.FONT, text=duration_text, scale = 2, color=color )
duration_text_area.x = 5
duration_text_area.y = 90
then append the text areas, show and refresh:
screen.append(fail_text_area)
screen.append(restore_text_area)
screen.append(duration_text_area)
display.refresh()
