Erase Flash UF2 file
AmazingCircuitPythonFR35
Post by AmazingCircuitPythonFR35 »
I've got many different boards running CircuitPython.
Sometimes one of them is no longer recognised by my PC. The COM port remains visible, but no drive...
In this case I use a UF2 file which erases the entire Flash memory, but I spend time looking for this file in your website.
Is there a web page that centralizes all these files for each of your cards?
Thank you for your answer.
Mike
dastels
Re: Erase Flash UF2 file
Post by dastels »
There is most likely some relevant information on the CircuitPython troubleshooting page: https://learn.adafruit.com/welcome-to-c ... leshooting, specifically this section: https://learn.adafruit.com/welcome-to-c ... 2987288-32.
dastels wrote:There is most likely some relevant information on the CircuitPython troubleshooting page: https://learn.adafruit.com/welcome-to-c ... leshooting, specifically this section: https://learn.adafruit.com/welcome-to-c ... 2987288-32.
Thanks a lot Dave.
And is there a place to find a uf2 file to erase the flash memory for other boards than Adafruit's boards ?
I know for example the 'flash_nuke.uf2' for the raspberry pico.
Mike
dastels
Post by dastels »
If it's a CircutiPython board and you can get to the REPL you can use storage.erase_filesystem(). Other than that I don't know.
dastels wrote:If it's a CircutiPython board and you can get to the REPL you can use storage.erase_filesystem(). Other than that I don't know.
Thanks Dave and have a nice day.
