Total beginner here, trying to get the built-in NeoPixel to work.
I want to use MicroPython, so most of the product documentation for ItsyBitsy RP2040 which is exculsively available for CircuitPython is not really helpful. Using Pin 17 as per info on https://learn.adafruit.com/adafruit-its ... 40/pinouts : "The RGB NeoPixel LED is located near A0 and A1 on the silk. It is controllable in CircuitPython code using the pin board.NEOPIXEL. It is on RP2040 pin GPIO17."
Got a sample from the MicroPython website at https://docs.micropython.org/en/latest/ ... 106-driver, but it does absolutely nothing.
from machine import Pin
from neopixel import NeoPixel
pin = Pin(17, Pin.OUT)
np = NeoPixel(pin, 1)
np[0] = (255, 255, 255)
np.write()
What am I doing wrong?
Itsy Bitsy RP2040 NeoPixel problem - MicroPython
- infoberg
- danhalbert
Re: Itsy Bitsy RP2040 NeoPixel problem - MicroPython
GPIO16 controls whether the NeoPixel gets power. You need to make it high to turn on the NeoPixel.
I will add something to the guide to make that clear.
- infoberg
Thanks, that did the trick!
- blakebr
Watching/Tracking
