Hi, I have been trying to use a Trinket M0 with a Neopixel. I had no success with arduino IDE so I used circuitpython. I have tried a bunch of examples, the only one that worked for me is this simple one: https://github.com/garyexplains/example ... /blinky.py
I have tried all other examples but no luck, even with the internal dotstar example that supposedly should work: https://github.com/garyexplains/example ... /rgbled.py
Since my main goal was to follow this tutorial: https://learn.adafruit.com/breath-of-th ... ython-code
I tried pasting this code, and it did not work. After experimenting a bit, it seems that the issue happens with import neopixel. The central dotstar flashes red even when my program only has this one import statement. Since the import statement was bugged I could not proceed and debug further.
I am using circuitpython 7.0.0, neopixel.mpy from the 20211221 release.
Any suggestions are greatly appreciated!!!
Error importing neopixel in circuitpython
- tannewt
Re: Error importing neopixel in circuitpython
Please connect to the serial output of the board and see what the error is and post it here along with the full code.py.
Instructions on how to do that are here: https://learn.adafruit.com/welcome-to-c ... al-console
- WeihengFu
Unfortunately trinket M0 does not have serial, and the metro I own is not compatible with circuitpython either. I did have success with arduino ide in the end; for those of you that also tried the example code, don't trust the demo too much. In my case the trinket m0 red led is port 13, but demo uses port 1 and that caused the 'error'.
Anyways thank you for your reply! I will definitely try debugging circuitpython once I buy a circuitpython board with serial in the future.
- tannewt
CircuitPython does serial over USB by default. Any CircuitPython board with USB will have this.
