Hi!
I'm trying to control a TLC59711 with a Trinket M0. I had no problem doing so with the CircuitPython version shipped with the Trinket M0.
However, after upgrading CircuitPython to 7.1 and using the related TLC59711 library, I cannot make the example "tlc59711_simpletest.py" program run without errors.
I tried the following scenarios and no luck so far.
> pixels = adafruit_tlc59711.TLC59711(spi, pixel_count=16)
generates MemoryError: memory allocation failed, allocating 184 bytes
If I change to 4 leds instead:
> pixels = adafruit_tlc59711.TLC59711(spi, pixel_count=4)
generates OverflowError: small int overflow
If I change to 3 leads instead:
It works, but then writing to one led:
> pixels.r0 = 100
generates RuntimeError: Buffer too small
Would anyone have any tip?
Trinket M0, TLC59711 and CircuitPython 7.1
- tomeskenazi
- deepSparse2
Re: Trinket M0, TLC59711 and CircuitPython 7.1
Hi!
I ran into the same memory allocation problem using a M0 ItsyBitsy to control the TLC59711 with CircuitPython 7.1. I think this was because the default number of pixels was 16, but I'm not totally sure.
My workaround was to remove as much code as possible from the TLC59711 library to reduce its memory usage, then add this file to the /lib folder of my ItsyBitsy. I've attached the lib file I used (adafruit_tlc59711_brief.py) and the main code (test-leds.py) below. Unfortunately, this only allowed me to use TLC59711.set_channel() to control the LED. The main code turns each LED on then off sequentially.
Other possible solutions:
1. Downgrade both CircuitPython and TLC59711 python library to a previous stable version (maybe version 6.3?)
2. Use Arduino IDE + Arduino library for TLC59711. I tried using the Arduino library, but I ran into a problem where the ItsyBitsy would disconnect from the serial monitor after the sketch was uploaded. Please see this thread for more info: viewtopic.php?f=62&t=186669&p=904531&hi ... 11#p904531
To those at Adafruit:
1. Does someone have insight into a better solution?
2. Should we open a new issue in the TLC59711 github: https://github.com/adafruit/Adafruit_Ci ... 711/issues?
- test-LEDs.py
- (638 Bytes) Downloaded 6 times
- adafruit_tlc59711_brief.py
- (9.18 KiB) Downloaded 6 times
- tomeskenazi
Thanks a lot @deepSpare2, very much appreciated. I will try with Arduino.
I investigated a bit further and it seems the TLC59711 library version for CircuitPython 7.1 may not work with small int boards.
Could we have a confirmation from Adafruit?
I could successfully pass the memory allocation by removing the TLC59711AutoShow class and regenerating the mpy.
However, even with a pixel_count = 4 (minimum for one chip), I cannot pass the TLC59711 class constructor:
File "main.py", line 23, in <module>
File "adafruit_tlc59711.py", line 306, in __init__
File "adafruit_tlc59711.py", line 315, in _init_buffer
File "adafruit_tlc59711.py", line 438, in _chip_set_WriteCommand
File "adafruit_tlc59711.py", line 327, in set_chipheader_bits_in_buffer
I'm afraid my knowledge is a little limited as this is my first time working with Adafruit products. Perhaps someone could help further?
Thank you very much.
- danhalbert
It does appear that the TLC5971111 driver is assuming it can use 32-bit integers. This is probably fixable, but I don't see an immediate fix. Please open an issue in https://github.com/adafruit/Adafruit_Ci ... 711/issues. In the meantime, if you have another board that is not a small build like the Trinket M0, you could try that. The Trinket and Gemma M0 builds are very skinny and really limit what you can do.
- tomeskenazi
Thanks @danalbert for confirming the issue.
I opened a new issue as suggested:
https://github.com/adafruit/Adafruit_Ci ... /issues/21
