The setup:
Sparkfun Thing+ RP2040
PNY 16GB Elite Class 10 MicroSDHC
Code:
import os
import board
import sdcardio
import storage
import busio
import random
import io
import time
ITERATIONS = 100
BUFFER_SIZE = 512
times = [0] * ITERATIONS
sum = 0
spi = busio.SPI(board.SD_SCK, MOSI=board.SD_MOSI, MISO=board.SD_MISO)
sdcard = sdcardio.SDCard(spi, board.SD_CS, baudrate=50_000_000)
vfs = storage.VfsFat(sdcard)
storage.mount(vfs, '/sd')
logfile = open("/sd/test.bin", "wb")
for i in range(0, ITERATIONS):
data = bytes(os.urandom(BUFFER_SIZE))
start = time.monotonic_ns()
logfile.write(data)
stop = time.monotonic_ns()
elapsed_ms = (stop - start) / 1_000_000
times[i] = elapsed_ms
sum = sum + elapsed_ms
print(f"Iteration: {i + 1} Length: {len(data)} elapsed: {elapsed_ms}ms")
logfile.close()
storage.umount(vfs)
vfs.umount()
times.sort()
med = times[ITERATIONS // 2]
avg = sum / ITERATIONS
max = times[ITERATIONS - 1]
min = times[0]
print(f"\nMedian: {med} Average: {avg} Minimum: {min} Maximum: {max}")
Iteration: 1 Length: 512 elapsed: 2.92969ms
Iteration: 2 Length: 512 elapsed: 1.95313ms
Iteration: 3 Length: 512 elapsed: 1.95313ms
Iteration: 4 Length: 512 elapsed: 1.95313ms
Iteration: 5 Length: 512 elapsed: 1.95313ms
Iteration: 6 Length: 512 elapsed: 1.95313ms
Iteration: 7 Length: 512 elapsed: 2.92969ms
Iteration: 8 Length: 512 elapsed: 1.95313ms
Iteration: 9 Length: 512 elapsed: 1.95313ms
Iteration: 10 Length: 512 elapsed: 1.95313ms
Iteration: 11 Length: 512 elapsed: 1.95313ms
Iteration: 12 Length: 512 elapsed: 2.92969ms
Iteration: 13 Length: 512 elapsed: 2.92969ms
Iteration: 14 Length: 512 elapsed: 1.95313ms
Iteration: 15 Length: 512 elapsed: 1.95313ms
Iteration: 16 Length: 512 elapsed: 2.92969ms
Iteration: 17 Length: 512 elapsed: 1.95313ms
Iteration: 18 Length: 512 elapsed: 1.95313ms
Iteration: 19 Length: 512 elapsed: 1.95313ms
Iteration: 20 Length: 512 elapsed: 1.95313ms
Iteration: 21 Length: 512 elapsed: 1.95313ms
Iteration: 22 Length: 512 elapsed: 1.95313ms
Iteration: 23 Length: 512 elapsed: 2.92969ms
Iteration: 24 Length: 512 elapsed: 2.92969ms
Iteration: 25 Length: 512 elapsed: 1.95313ms
Iteration: 26 Length: 512 elapsed: 1.95313ms
Iteration: 27 Length: 512 elapsed: 1.95313ms
Iteration: 28 Length: 512 elapsed: 1.95313ms
Iteration: 29 Length: 512 elapsed: 1.95313ms
Iteration: 30 Length: 512 elapsed: 1.95313ms
Iteration: 31 Length: 512 elapsed: 1.95313ms
Iteration: 32 Length: 512 elapsed: 1.95313ms
Iteration: 33 Length: 512 elapsed: 1.95313ms
Iteration: 34 Length: 512 elapsed: 1.95313ms
Iteration: 35 Length: 512 elapsed: 1.95313ms
Iteration: 36 Length: 512 elapsed: 1.95313ms
Iteration: 37 Length: 512 elapsed: 1.95313ms
Iteration: 38 Length: 512 elapsed: 1.95313ms
Iteration: 39 Length: 512 elapsed: 1.95313ms
Iteration: 40 Length: 512 elapsed: 1.95313ms
Iteration: 41 Length: 512 elapsed: 1.95313ms
Iteration: 42 Length: 512 elapsed: 1.95313ms
Iteration: 43 Length: 512 elapsed: 1.95313ms
Iteration: 44 Length: 512 elapsed: 1.95313ms
Iteration: 45 Length: 512 elapsed: 1.95313ms
Iteration: 46 Length: 512 elapsed: 2.92969ms
Iteration: 47 Length: 512 elapsed: 2.92969ms
Iteration: 48 Length: 512 elapsed: 1.95313ms
Iteration: 49 Length: 512 elapsed: 2.92969ms
Iteration: 50 Length: 512 elapsed: 2.92969ms
Iteration: 51 Length: 512 elapsed: 1.95313ms
Iteration: 52 Length: 512 elapsed: 1.95313ms
Iteration: 53 Length: 512 elapsed: 1.95313ms
Iteration: 54 Length: 512 elapsed: 1.95313ms
Iteration: 55 Length: 512 elapsed: 1.95313ms
Iteration: 56 Length: 512 elapsed: 1.95313ms
Iteration: 57 Length: 512 elapsed: 1.95313ms
Iteration: 58 Length: 512 elapsed: 7.8125ms
Iteration: 59 Length: 512 elapsed: 1.95313ms
Iteration: 60 Length: 512 elapsed: 1.95313ms
Iteration: 61 Length: 512 elapsed: 1.95313ms
Iteration: 62 Length: 512 elapsed: 2.92969ms
Iteration: 63 Length: 512 elapsed: 2.92969ms
Iteration: 64 Length: 512 elapsed: 2.92969ms
Iteration: 65 Length: 512 elapsed: 1.95313ms
Iteration: 66 Length: 512 elapsed: 1.95313ms
Iteration: 67 Length: 512 elapsed: 1.95313ms
Iteration: 68 Length: 512 elapsed: 1.95313ms
Iteration: 69 Length: 512 elapsed: 2.92969ms
Iteration: 70 Length: 512 elapsed: 1.95313ms
Iteration: 71 Length: 512 elapsed: 1.95313ms
Iteration: 72 Length: 512 elapsed: 1.95313ms
Iteration: 73 Length: 512 elapsed: 1.95313ms
Iteration: 74 Length: 512 elapsed: 2.92969ms
Iteration: 75 Length: 512 elapsed: 1.95313ms
Iteration: 76 Length: 512 elapsed: 1.95313ms
Iteration: 77 Length: 512 elapsed: 1.95313ms
Iteration: 78 Length: 512 elapsed: 1.95313ms
Iteration: 79 Length: 512 elapsed: 1.95313ms
Iteration: 80 Length: 512 elapsed: 1.95313ms
Iteration: 81 Length: 512 elapsed: 1.95313ms
Iteration: 82 Length: 512 elapsed: 1.95313ms
Iteration: 83 Length: 512 elapsed: 1.95313ms
Iteration: 84 Length: 512 elapsed: 1.95313ms
Iteration: 85 Length: 512 elapsed: 2.92969ms
Iteration: 86 Length: 512 elapsed: 2.92969ms
Iteration: 87 Length: 512 elapsed: 2.92969ms
Iteration: 88 Length: 512 elapsed: 1.95313ms
Iteration: 89 Length: 512 elapsed: 1.95313ms
Iteration: 90 Length: 512 elapsed: 1.95313ms
Iteration: 91 Length: 512 elapsed: 1.95313ms
Iteration: 92 Length: 512 elapsed: 1.95313ms
Iteration: 93 Length: 512 elapsed: 1.95313ms
Iteration: 94 Length: 512 elapsed: 1.95313ms
Iteration: 95 Length: 512 elapsed: 1.95313ms
Iteration: 96 Length: 512 elapsed: 1.95313ms
Iteration: 97 Length: 512 elapsed: 1.95313ms
Iteration: 98 Length: 512 elapsed: 2.92969ms
Iteration: 99 Length: 512 elapsed: 1.95313ms
Iteration: 100 Length: 512 elapsed: 1.95313ms
Median: 1.95313 Average: 2.20703 Minimum: 1.95313 Maximum: 7.8125
