SDCARD performance
thezim
SDCARD performance
Post by thezim »
It there anyway to squeeze more performance out of sdcardio under CircuitPython?
The setup:
Sparkfun Thing+ RP2040
PNY 16GB Elite Class 10 MicroSDHC
Code:
import os
import board
import sdcardio
import storage
import busio
import random
import io
import time
ITERATIONS = 100
BUFFER_SIZE = 512
times = [0] * ITERATIONS
sum = 0
spi = busio.SPI(board.SD_SCK, MOSI=board.SD_MOSI, MISO=board.SD_MISO)
sdcard = sdcardio.SDCard(spi, board.SD_CS, baudrate=50_000_000)
vfs = storage.VfsFat(sdcard)
storage.mount(vfs, '/sd')
logfile = open("/sd/test.bin", "wb")
for i in range(0, ITERATIONS):
    data = bytes(os.urandom(BUFFER_SIZE))
    start = time.monotonic_ns()
    logfile.write(data)
    stop = time.monotonic_ns()
    elapsed_ms = (stop - start) / 1_000_000
    times[i] = elapsed_ms
    sum = sum + elapsed_ms
    print(f"Iteration: {i + 1} Length: {len(data)} elapsed: {elapsed_ms}ms")
logfile.close()
storage.umount(vfs)
vfs.umount()
times.sort()
med = times[ITERATIONS // 2]
avg = sum / ITERATIONS
max = times[ITERATIONS - 1]
min = times[0]
print(f"\nMedian: {med} Average: {avg} Minimum: {min} Maximum: {max}")
Output:
Iteration: 1 Length: 512 elapsed: 2.92969ms
Iteration: 2 Length: 512 elapsed: 1.95313ms
Iteration: 3 Length: 512 elapsed: 1.95313ms
Iteration: 4 Length: 512 elapsed: 1.95313ms
Iteration: 5 Length: 512 elapsed: 1.95313ms
Iteration: 6 Length: 512 elapsed: 1.95313ms
Iteration: 7 Length: 512 elapsed: 2.92969ms
Iteration: 8 Length: 512 elapsed: 1.95313ms
Iteration: 9 Length: 512 elapsed: 1.95313ms
Iteration: 10 Length: 512 elapsed: 1.95313ms
Iteration: 11 Length: 512 elapsed: 1.95313ms
Iteration: 12 Length: 512 elapsed: 2.92969ms
Iteration: 13 Length: 512 elapsed: 2.92969ms
Iteration: 14 Length: 512 elapsed: 1.95313ms
Iteration: 15 Length: 512 elapsed: 1.95313ms
Iteration: 16 Length: 512 elapsed: 2.92969ms
Iteration: 17 Length: 512 elapsed: 1.95313ms
Iteration: 18 Length: 512 elapsed: 1.95313ms
Iteration: 19 Length: 512 elapsed: 1.95313ms
Iteration: 20 Length: 512 elapsed: 1.95313ms
Iteration: 21 Length: 512 elapsed: 1.95313ms
Iteration: 22 Length: 512 elapsed: 1.95313ms
Iteration: 23 Length: 512 elapsed: 2.92969ms
Iteration: 24 Length: 512 elapsed: 2.92969ms
Iteration: 25 Length: 512 elapsed: 1.95313ms
Iteration: 26 Length: 512 elapsed: 1.95313ms
Iteration: 27 Length: 512 elapsed: 1.95313ms
Iteration: 28 Length: 512 elapsed: 1.95313ms
Iteration: 29 Length: 512 elapsed: 1.95313ms
Iteration: 30 Length: 512 elapsed: 1.95313ms
Iteration: 31 Length: 512 elapsed: 1.95313ms
Iteration: 32 Length: 512 elapsed: 1.95313ms
Iteration: 33 Length: 512 elapsed: 1.95313ms
Iteration: 34 Length: 512 elapsed: 1.95313ms
Iteration: 35 Length: 512 elapsed: 1.95313ms
Iteration: 36 Length: 512 elapsed: 1.95313ms
Iteration: 37 Length: 512 elapsed: 1.95313ms
Iteration: 38 Length: 512 elapsed: 1.95313ms
Iteration: 39 Length: 512 elapsed: 1.95313ms
Iteration: 40 Length: 512 elapsed: 1.95313ms
Iteration: 41 Length: 512 elapsed: 1.95313ms
Iteration: 42 Length: 512 elapsed: 1.95313ms
Iteration: 43 Length: 512 elapsed: 1.95313ms
Iteration: 44 Length: 512 elapsed: 1.95313ms
Iteration: 45 Length: 512 elapsed: 1.95313ms
Iteration: 46 Length: 512 elapsed: 2.92969ms
Iteration: 47 Length: 512 elapsed: 2.92969ms
Iteration: 48 Length: 512 elapsed: 1.95313ms
Iteration: 49 Length: 512 elapsed: 2.92969ms
Iteration: 50 Length: 512 elapsed: 2.92969ms
Iteration: 51 Length: 512 elapsed: 1.95313ms
Iteration: 52 Length: 512 elapsed: 1.95313ms
Iteration: 53 Length: 512 elapsed: 1.95313ms
Iteration: 54 Length: 512 elapsed: 1.95313ms
Iteration: 55 Length: 512 elapsed: 1.95313ms
Iteration: 56 Length: 512 elapsed: 1.95313ms
Iteration: 57 Length: 512 elapsed: 1.95313ms
Iteration: 58 Length: 512 elapsed: 7.8125ms
Iteration: 59 Length: 512 elapsed: 1.95313ms
Iteration: 60 Length: 512 elapsed: 1.95313ms
Iteration: 61 Length: 512 elapsed: 1.95313ms
Iteration: 62 Length: 512 elapsed: 2.92969ms
Iteration: 63 Length: 512 elapsed: 2.92969ms
Iteration: 64 Length: 512 elapsed: 2.92969ms
Iteration: 65 Length: 512 elapsed: 1.95313ms
Iteration: 66 Length: 512 elapsed: 1.95313ms
Iteration: 67 Length: 512 elapsed: 1.95313ms
Iteration: 68 Length: 512 elapsed: 1.95313ms
Iteration: 69 Length: 512 elapsed: 2.92969ms
Iteration: 70 Length: 512 elapsed: 1.95313ms
Iteration: 71 Length: 512 elapsed: 1.95313ms
Iteration: 72 Length: 512 elapsed: 1.95313ms
Iteration: 73 Length: 512 elapsed: 1.95313ms
Iteration: 74 Length: 512 elapsed: 2.92969ms
Iteration: 75 Length: 512 elapsed: 1.95313ms
Iteration: 76 Length: 512 elapsed: 1.95313ms
Iteration: 77 Length: 512 elapsed: 1.95313ms
Iteration: 78 Length: 512 elapsed: 1.95313ms
Iteration: 79 Length: 512 elapsed: 1.95313ms
Iteration: 80 Length: 512 elapsed: 1.95313ms
Iteration: 81 Length: 512 elapsed: 1.95313ms
Iteration: 82 Length: 512 elapsed: 1.95313ms
Iteration: 83 Length: 512 elapsed: 1.95313ms
Iteration: 84 Length: 512 elapsed: 1.95313ms
Iteration: 85 Length: 512 elapsed: 2.92969ms
Iteration: 86 Length: 512 elapsed: 2.92969ms
Iteration: 87 Length: 512 elapsed: 2.92969ms
Iteration: 88 Length: 512 elapsed: 1.95313ms
Iteration: 89 Length: 512 elapsed: 1.95313ms
Iteration: 90 Length: 512 elapsed: 1.95313ms
Iteration: 91 Length: 512 elapsed: 1.95313ms
Iteration: 92 Length: 512 elapsed: 1.95313ms
Iteration: 93 Length: 512 elapsed: 1.95313ms
Iteration: 94 Length: 512 elapsed: 1.95313ms
Iteration: 95 Length: 512 elapsed: 1.95313ms
Iteration: 96 Length: 512 elapsed: 1.95313ms
Iteration: 97 Length: 512 elapsed: 1.95313ms
Iteration: 98 Length: 512 elapsed: 2.92969ms
Iteration: 99 Length: 512 elapsed: 1.95313ms
Iteration: 100 Length: 512 elapsed: 1.95313ms
Median: 1.95313 Average: 2.20703 Minimum: 1.95313 Maximum: 7.8125
thezim
Re: SDCARD performance
Post by thezim »
I ask because I have busy can bus (Tesla Model 3) with a median period of 351 microseconds between can frames. 1.9ms is way too long to without losing frames. Even if buffered to 512 byes I'm not even sure under CircuitPython or MicroPython that write call here is a blocking, preventing the ability to even buffer.
blakebr
Post by blakebr »
Zim,
Take a look at the Raspberry Pi Zero 2 W. It is much faster than the RP2040
There is a version of Circuit Python that will run on it.
Python 3 comes with the OS that is native to the Raspberry Pi Series.
Good Luck with your project.
Bruce
adafruit-circuitpython-raspberrypi_zero2w-en_US-20220113-936c9b2.disk.img.zip
