PyPortal Thingiverse Viewer
I have been trying to get John Parks' PyPortal Thingiverse Viewer working on my PyPortal.
I have downloaded all the files and double checked that I have all the necessary files. See attached screen shot of my PyPortal files.
I have attached the code.py file I am using from John Parks.
Here is the code.py output that I get when running the code. I seem to be caught in some kind of loop.
code.py output:
Preloading font glyphs: b'0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ-!,. "\'?!'
Connecting to AP Honda
Retrieving data...Reply is OK!
Code stopped by auto-reload.
soft reboot
code.py output:
soft reboot
Can you suggest any corrections I need to make to get this program to run correctly?
Thank you,
Tom Henry
John Parks PyPortal Thingiverse Viewer
- Tom_Henry
- code.py
- (2.06 KiB) Downloaded 2 times
- Screen Shot from Tom Henry.png (183.35 KiB) Viewed 78 times
- dastels
Re: John Parks PyPortal Thingiverse Viewer
It seems to be running fine but the "a file changed so I'll reload" thing is happening. Your OS must be poking at the board occasionally. It's useful while working on code, but annoying once you just want to run it.
Have a look at https://learn.adafruit.com/welcome-to-c ... 3108374-19
- Tom_Henry
I tired turning off Auto-reload.
Here is my new output (see below), and I have attached my modified code.py.
Getting an error, something about failing to request hostname. I'm not sure what that means.
Tom Henry
Auto-reload is off.
code.py output:
Preloading font glyphs: b'0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ-!,. “\'?!'
Retrieving data...Some error occured, retrying! - Failed to request hostname
Tom Henry
Auto-reload is off.
code.py output:
- code.py
- (2.11 KiB) Downloaded 2 times
- Tom_Henry
I just ran it a second time, and it seems auto-reload is still a problem:
Auto-reload is off.
code.py output:
soft reboot
Auto-reload is off.
code.py output:
soft reboot
- dastels
It's Wifi and it's the Internet... you'll get errors. In most situation you never see those errors ... the next attempt often works. If it never works, then there's a more serious problem.
The "auto-reload is off" ... "stopped by auto-reload" is kind of odd, though.
