Hello folks,
Is there a good way to reboot the Titano through software?
My code that pulls in a JSON from a URL, parses it and displays values on the LCD hangs after every few hours of running.
Right now, I have a GPIO wired to the RESET button, and I toggle it every hour to reboot.
Is there a cleaner way to do this?
Pyportal Titano auto reboot
- dastels
Re: Pyportal Titano auto reboot
I would want to figure out why it's hanging. Is there a memory leak? Is it a Wifi issue that isn't being handled? It could be one of many things. If the time to lockup is fairly consistent I'd start suspecting a memory issue.
Are you using CircuitPython or C++ (aka Arduino)?
- thesassyindian
I’m using Arduino.
- dastels
C++ means more potential for memory problems. Can you post your code?
- dastels
As a brute force approach you might be able to do something with a TPL5111 using https://www.adafruit.com/product/3573 with the ENout connected to the PyPortal's reset pin which is available at the SWD connector pads.
- thesassyindian
There’s absolutely no need for external hardware!
I just pull a GPIO pin low every hour (using NTP time) that’s connected to the pyportal’s RESET button.
Once the MCU turns off, that gpio is pulled high internally.
- dastels
Ok then, that cool. Back you my first comment: find and fix the problem.
