I don't know if this is intended and I am just not familiar enough with it but I was building a servo slower that took R/C 50hz 1-2ms pwm inputs on MI and when I had it process the signal and issue commands on MO via the servo command from the motor library it would, every four seconds or so, disrupt the PWM input on MI causing it to read zero, then gibberish for several cycles. I tried several workarounds but it looks like the only real option is using a different pin and that seems to be holding steady but I don't want to run into this issue later after x thousand cycles or something. Should I be worried about that?
hardware: level shifter and QT Py RP2040
Software 7.1.1, 7.1.2 beta tried too, same result.
QTPY RP2040 PWM output on MO disrupts PWM input on MI
- Probotics
- danhalbert
Re: QTPY RP2040 PWM output on MO disrupts PWM input on MI
Could your post your code so we can try it out?
- Probotics
# servo slower
import pulseio
import board
import pwmio
import time
from adafruit_motor import servo
p_pulseIn1 = pulseio.PulseIn(board.D0)
pwm = pwmio.PWMOut(board.MOSI, duty_cycle=0, frequency=333)
servo = servo.Servo(pwm, min_pulse=800, max_pulse=2200)
v_count = 0
while len(p_pulseIn1) == 0:
pass
v_currentLocation = p_pulseIn1[0]
p_pulseIn1.pause()
p_pulseIn1.clear()
def get_a_pulse(vl_pulseIn):
vl_pulseIn.resume()
while len(vl_pulseIn) == 0:
pass
vl_pulseIn.pause()
def slow_pulse(vl_pulseinval, vl_currentLocation):
if vl_currentLocation > vl_pulseinval:
v_newLocation = max(vl_pulseinval, vl_currentLocation - 30)
elif vl_currentLocation < vl_pulseinval:
v_newLocation = min(vl_pulseinval, vl_currentLocation + 30)
else:
v_newLocation = vl_pulseinval
v_newLocation = max(800, v_newLocation)
servo.fraction = ((v_newLocation-800)/1400)
vl_currentLocation = v_newLocation
time.sleep(0.01)
return vl_currentLocation
while True:
get_a_pulse(p_pulseIn1)
v_pulseIn1 = p_pulseIn1[0]
v_currentLocation = slow_pulse(v_pulseIn1, v_currentLocation)
v_count = v_count + 1
# if v_pulseIn1 < 1000:
print("pulse 1 ", v_pulseIn1)
print("pulse out", v_currentLocation)
print(v_count)
p_pulseIn1.clear()
- danhalbert
I lost track of this old issue, sorry. Are you still seeing this problem? At the very least we can record it in an issue.
