I have looked at many examples trying to get the VL53L1X with a Pico using the code shown with circuit python examples. I continue to encounter errors win the initial part of the code:
# Simple demo of the VL53L1X distance sensor.
# Will print the sensed range/distance every second.
import time
import board
import adafruit_vl53l1x
i2c = board.I2C()
vl53 = adafruit_vl53l1x.VL53L1X(i2c)
One example referred to the fact that the line "i2c = board.I2C()" would have to be changed for the Pico, but all attempts have failed. If I use busio instead of boards it faults at the next line.
Any help would be highly appreciated
vl53l1x with raspberry pi pico in cirquit python
- arucano
- tannewt
Re: vl53l1x with raspberry pi pico in cirquit python
There are instructions on initializing I2C on the Pico here: https://learn.adafruit.com/getting-star ... on/pinouts
If you still have issues, please post the exact code you have and the error message that goes with it.
- arucano
I used the following code, cobbled up from some examples. I am able to detect the address of the VL53L1X but hit a roadblock at line 16. Below are the code and error messages.
CODE:
ERROR MESSAGE
I2C addresses found: ['0x29']
File "<stdin>", line 16, in <module>
TypeError: 'scl' argument required
CODE:
import busio
import board
import time
i2c = busio.I2C(board.GP1, board.GP0)
# added for detection
# Lock the I2C device before we try to scan
while not i2c.try_lock():
pass
# Print the addresses found once
print("I2C addresses found:", [hex(device_address) for device_address in i2c.scan()])
# Unlock I2C now that we're done scanning.
i2c.unlock()
vl53 = adafruit_vl53l1x.VL53L1X(busio.I2C())
while True:
print("range: mm ", vl53.read())
time.sleep_ms(50)
Reason: added code block
- tannewt
