MatrixPortal Memory Error
MakerMelissa
Re: MatrixPortal Memory Error
Post by MakerMelissa »
Ok, I now have a PR in to freeze the PortalBase library and make use of some of the other libraries that were already frozen in here: https://github.com/adafruit/circuitpython/pull/6043. It likely won't be in there until the next release of CircuitPython.
Tortilla
Post by Tortilla »
MakerMelissa wrote:Ok, I now have a PR in to freeze the PortalBase library and make use of some of the other libraries that were already frozen in here: https://github.com/adafruit/circuitpython/pull/6043. It likely won't be in there until the next release of CircuitPython.
Thanks! I'm looking forward to trying it out.
jliu70
Post by jliu70 »
So just out of curiosity, would you show the contents of your CIRCUITPY lib folder?
Are all the libraries ".mpy" versions?
Jeff
dastels
Post by dastels »
jliu70 wrote:So just out of curiosity, would you show the contents of your CIRCUITPY lib folder?
Jeff
You really should read the entire thread.
jliu70
Post by jliu70 »
Jeff
I saw the post stating that all the libraries were ".mpy", but from the code snippet, it seemed to only be making a call to one external library. adafruit_datetime and perhaps terminal.
"""One panel display using 64 X 32 RGB panel to scroll ESPN game information"""
import gc
import time
import json
from adafruit_datetime import datetime, timedelta
import board
from adafruit_matrixportal.matrixportal import MatrixPortal
Memory_free = gc.mem_free()
print("Total memory free right after importing matrixportal library is", Memory_free)
# import terminalio
I was just wondering if that was the case that he was only using the two libraries, of if there were additional libraries being used.
And I wasn't quite understanding if the issue was with the RAM or with the storage on the MatrixPortal.
Jeff
MakerMelissa
It's now merged in. You can try out one of the automated builds if you want: https://adafruit-circuit-python.s3.amaz ... portal_m4/. You'll notice a slight rise in size for the ones with the libraries frozen in. You should be able to run it without installing the following libraries:
Adafruit_CircuitPython_PortalBase
Adafruit_CircuitPython_Requests
Adafruit_CircuitPython_ESP32SPI
Adafruit_CircuitPython_NeoPixel
Tortilla
Post by Tortilla »
I'm definetly going to try it this weekend. Thanks again!
jliu70
Post by jliu70 »
Just out of curiosity, I gave it a try,
Looks like the memory error persists, but I don't know if it's because I'm not loading the "mpy" versions of the libraries.
Here's the REPL output:
Adafruit CircuitPython 7.2.0-alpha.2-27-g57bbe7922 on 2022-02-18; Adafruit Matrix Portal M4 with samd51j19
soft reboot
code.py output:
Total memory free right before importing matrixportal library is 99216
Total memory free right after importing matrixportal library is 72576
Total memory free right before matrixportal call is 71952
Connecting to AP FiOS-ZG466
Retrieving data...Reply is OK!
  File "code.py", line 193, in <module>
  File "code.py", line 140, in fetch_sports_data
  File "adafruit_portalbase/__init__.py", line 412, in fetch
  File "adafruit_portalbase/network.py", line 560, in fetch_data
  File "adafruit_portalbase/network.py", line 591, in _parse_data
MemoryError: memory allocation failed, allocating 65 bytes (data is likely too large)
Code done running.
Here's the contents of the CIRCUITPY/lib folder:
(circup) jliu@JEFFREYs-MBP ~/git/jliu-circuitpython-examples  % ls -l /Volumes/CIRCUITPY/lib
total 104
drwxrwxrwx  1 jliu  staff   1024 Feb 18 17:01 adafruit_bitmap_font
drwxrwxrwx  1 jliu  staff   1024 Feb 18 17:01 adafruit_bus_device
-rwxrwxrwx  1 jliu  staff  18705 Feb 18 16:53 adafruit_datetime.mpy
drwxrwxrwx  1 jliu  staff   1024 Feb 18 17:01 adafruit_display_shapes
drwxrwxrwx  1 jliu  staff   1024 Feb 18 17:01 adafruit_display_text
drwxrwxrwx  1 jliu  staff   1024 Feb 18 17:01 adafruit_esp32spi
-rwxrwxrwx  1 jliu  staff    363 Feb 18 17:00 adafruit_fakerequests.mpy
drwxrwxrwx  1 jliu  staff   1024 Feb 18 17:01 adafruit_imageload
drwxrwxrwx  1 jliu  staff   1024 Feb 18 17:01 adafruit_io
drwxrwxrwx  1 jliu  staff   1024 Feb 18 17:01 adafruit_matrixportal
-rwxrwxrwx  1 jliu  staff   6596 Feb 18 17:00 adafruit_miniqr.mpy
-rwxrwxrwx  1 jliu  staff   3010 Feb 18 17:00 adafruit_pixelbuf.mpy
drwxrwxrwx  1 jliu  staff   1024 Feb 18 17:01 adafruit_portalbase
-rwxrwxrwx  1 jliu  staff   9188 Feb 18 17:00 adafruit_requests.mpy
-rwxrwxrwx  1 jliu  staff   1401 Feb 18 17:01 neopixel.mpy
-rwxrwxrwx  1 jliu  staff   1761 Feb 18 17:01 simpleio.mpy
MakerMelissa
jliu70 wrote:Just out of curiosity, I gave it a try,
total 104
Are you using the new circuitpython image with the frozen libraries? If so, you can delete the following:
adafruit_portalbase
adafruit_esp32spi
neopixel.mpy
adafruit_bus_device
I believe having those will actually override the frozen libraries and use the files in your lib folder instead, which would result in a memory error.
Melissa.
jliu70
Post by jliu70 »
Yes, I'm using the latest UF2
Followed your directions and removed the libraries from the CIRCUITPY/lib folder.
(circup) jliu@JEFFREYs-MBP ~  % ls -l /Volumes/CIRCUITPY/lib
total 76
-rwxrwxrwx  1 jliu  staff    363 Feb 18 17:23 adafruit_fakerequests.mpy
drwxrwxrwx  1 jliu  staff   1024 Feb 18 17:23 adafruit_matrixportal
Still seeing the memory error. REPL output below:
code.py output:
Total memory free right before importing matrixportal library is 99024
Total memory free right after importing matrixportal library is 73136
Total memory free right before matrixportal call is 72512
MemoryError:  (data is likely too large)
Code done running.
Tortilla
Post by Tortilla »
jliu70 wrote:Yes, I'm using the latest UF2
total 76
code.py output:
Code done running.
I think the memory error that you are seeing now is because the ESPN api is too large for the version of code that I originally posted and which you have been testing. Melissa's frozen library resulted in very significant increases in free memory after the library imports and is doing what it is supposed to do. I have learned that this project has to approached differently to be able to use the ESPN api's with a matrixportal (due to the memory limitation of the board). Since I posted my original code, I have reworked it and used a lot of memory saving tactics such as only importing the necessary fuctions from the modules, streamlining my code, removing the "double" framebuffer memory and other techniques. My original code that I posted was not really useable anyway, but I couldn't even debug it because of the initial memory error which was the subject of this thread. I have the matrixportal displayer up and running, but nevertheless, Melissa's efforts are greatly appreciated since I can still have memory errors when there are many games covered by an ESPN api on a given day. I just wanted to let you know so you might save some time trying to continue to test my rather bad initial code that I have completely reworked.
danhalbert
Post by danhalbert »
Is there any way to fetch less data at a time with the ESPN API, like a few hours at a time instead of a whole day, etc.?
jliu70
Post by jliu70 »
Just doing a raw dump of the two API calls, it looks like the data set returned are the following sizes:
 75281 College Baseball
106729 NHL
It does seem to dump back "everything".
For example the NHL json data snippet:
{"leagues":[{"id":"90","uid":"s:70~l:90","name":"National Hockey League","abbreviation":"NHL","slug":"nhl","season":{"year":2022,"startDate":"2021-07-21T07:00Z","endDate":"2022-07-01T06:59Z","type":{"id":"2","type":2,"name":"Regular Season","abbreviation":"reg"}},"calendarType":"day","calendarIsWhitelist":true,"calendarStartDate":"2021-07-21T07:00Z","calendarEndDate":"2022-07-01T06:59Z","calendar":["2021-09-25T07:00Z","2021-09-26T07:00Z","2021-09-27T07:00Z","2021-09-28T07:00Z","2021-09-29T07:00Z","2021-09-30T07:00Z","2021-10-01T07:00Z","2021-10-02T07:00Z","2021-10-03T07:00Z","2021-10-04T07:00Z","2021-10-05T07:00Z","2021-10-06T07:00Z","2021-10-07T07:00Z","2021-10-08T07:00Z","2021-10-09T07:00Z","2021-10-12T07:00Z","2021-10-13T07:00Z","2021-10-14T07:00Z","2021-10-15T07:00Z","2021-10-16T07:00Z","2021-10-17T07:00Z","2021-10-18T07:00Z","2021-10-19T07:00Z","2021-10-20T07:00Z","2021-10-21T07:00Z","2021-10-22T07:00Z","2021-10-23T07:00Z","2021-10-24T07:00Z","2021-10-25T07:00Z","2021-10-26T07:00Z","2021-10-27T07:00Z","2021-10-28T07:00Z","2021-10-29T07:00Z","2021-10-30T07:00Z","2021-10-31T07:00Z","2021-11-01T07:00Z","2021-11-02T07:00Z","2021-11-03T07:00Z","2021-11-04T07:00Z","2021-11-05T07:00Z","2021-11-06T07:00Z","2021-11-07T07:00Z","2021-11-08T08:00Z","2021-11-09T08:00Z","2021-11-10T08:00Z","2021-11-11T08:00Z","2021-11-12T08:00Z","2021-11-13T08:00Z","2021-11-14T08:00Z","2021-11-15T08:00Z","2021-11-16T08:00Z","2021-11-17T08:00Z","2021-11-18T08:00Z","2021-11-19T08:00Z","2021-11-20T08:00Z","2021-11-21T08:00Z","2021-11-22T08:00Z","2021-11-23T08:00Z","2021-11-24T08:00Z","2021-11-26T08:00Z","2021-11-27T08:00Z","2021-11-28T08:00Z","2021-11-29T08:00Z","2021-11-30T08:00Z","2021-12-01T08:00Z","2021-12-02T08:00Z","2021-12-03T08:00Z","2021-12-04T08:00Z","2021-12-05T08:00Z","2021-12-06T08:00Z","2021-12-07T08:00Z","2021-12-08T08:00Z","2021-12-09T08:00Z","2021-12-10T08:00Z","2021-12-11T08:00Z","2021-12-12T08:00Z","2021-12-13T08:00Z","2021-12-14T08:00Z"
So I searching online, I found a couple of gists which seem to provide info on the ESPN APIs.
The following API call seems to limit the returned data to the scores for the NHL for the current day:
https://site.web.api.espn.com/apis/v2/scoreboard/header?sport=hockey&league=nhl
The size of the returned NHL dataset is 44KB which probably will work since it's smaller than the 75KB free memory reported on the MatrixPortal.
Unfortunately the size of the returned college baseball dataset is 108KB which still seems to exceed the free memory.
https://site.web.api.espn.com/apis/v2/scoreboard/header?sport=baseball&league=college-baseball
danhalbert
At least on the hockey one, I can add `&dates=20220201` or `&dates=20220201-20220210`, and get different results.
