I have 3 funhouses writing environmental data to Adafruit IO. If they loose the network connection they will error out. To get around that I used smart sockets and triggered a power cycle every hour in case they loose connection, it will reset at least hourly. I was using tuya and ifttt, but apparently they are having a spat, so I cant add devices to that flow.
The better thing would to just have the funhouse reset if there was no connection found or wait for a period of time and try connecting again. Is there a clean way in circuitpython to do that?
reset Funhouse if no internet connection
- danhalbert
Re: reset Funhouse if no internet connection
If they are throwing an exception, you can catch the exception inside a try-catch block, and then decide what to do. You could even reset the board if you wanted to.
- tundra242
thanks, I was getting a lot of errors until I read everything has to be indented after the try:. Working so far.
