GROVE definition of i2c
blakebr
Post by blakebr »
Good Morning,
I have tried several ways to do the following and failed miserably.
This does not work.
GROVE4 = (board.GP7, board.GP6)
i2c = io.I2C(GROVE4)
I must use individual:
i2c = io.I2C(board.GP7, board.GP6)
I am using the Maker Pi Pico with my Raspberry Pi Pico and Maker Pi RP2040.
I want to be able to set up something like this in a library then pick what I want with just one label.
        GROVE1 = (board.GP1,  board.GP0); GR = "GR-1"
        GROVE2 = (board.GP3,  board.GP2); GR = "GR-2" # 1  GND
        GROVE3 = (board.GP5,  board.GP4); GR = "GR-3" # 2 +3V3
        GROVE4 = (board.GP7,  board.GP6); GR = "GR-4" # 3 Even Pin SDAn
        GROVE5 = (board.GP9,  board.GP8); GR = "GR-5" # 4 Odd  Pin SCLn
        GROVE6 = (board.GP27, board.GP26); GR = "GR-6"
How do I do what I want to do?
Bruce
dastels
Re: GROVE definition of i2c
Post by dastels »
Something like this will probably do the job:
i2c_pins = GROVE4 #for example... putting them in an array will probably be more useful
i2c = io.I2C(i2c_pins[0], i2c_pins[1])
blakebr
Post by blakebr »
Dave,
Your code worked. Thank you.
This is my selection code.
# define and select i2c GROVE port(s)
GROVE1 = False # (board.GP1,  board.GP0)
GROVE2 = False # (board.GP3,  board.GP2) # 1  GND
GROVE3 = False # (board.GP4,  board.GP4) # 2 +3V3
GROVE4 = True  # (board.GP7,  board.GP6) # 3 Even Pin SDAn
GROVE5 = False # (board.GP9,  board.GP8) # 4 Odd  Pin SCLn
GROVE6 = False # (board.GP27, board.GP26)
This is the implementation code.
        global i2c
        if   GROVE1: GROVEn = (board.GP1,  board.GP0); GR = "GR-1"
        elif GROVE2: GROVEn = (board.GP3,  board.GP2); GR = "GR-2" # 1  GND
        elif GROVE3: GROVEn = (board.GP5,  board.GP4); GR = "GR-3" # 2 +3V3
        elif GROVE4: GROVEn = (board.GP7,  board.GP6); GR = "GR-4" # 3 Even Pin SDAn
        elif GROVE5: GROVEn = (board.GP9,  board.GP8); GR = "GR-5" # 4 Odd  Pin SCLn
        elif GROVE6: GROVEn = (board.GP27, board.GP26); GR = "GR-6"
        i2c = io.I2C(GROVEn[0], GROVEn[1])
Bruce
dastels
Post by dastels »
You could simplify things if you used an integer in place of the 6 booleans. E.g. your selection code would become:
pins = [(),         # to start the pin pairs at 1 top correspond to the numbering in your code
        (board.GP1,  board.GP0),
        (board.GP3,  board.GP2),  # 1  GND
        (board.GP5,  board.GP4),  # 2 +3V3
        (board.GP7,  board.GP6),  # 3 Even Pin SDAn
        (board.GP9,  board.GP8);, # 4 Odd  Pin SCLn
grove = 4
And the implementation code would be:
i2c = io.I2C(pins[grove][0], pins[grove][1])
GR = "GR-{0}".format(grove)
blakebr
Post by blakebr »
Dave,
That is so much more elegant. Thank you.
Bruce
dastels
Post by dastels »
Simplifying/removing logic and replacing it with simple data structures will tend to make the code more elegant, error proof., and extendable. Now to add another set of pins you just need to add a tuple to the array. To reorder them you just edit the array definition. Any time you have to change code, you risk introducing an error.
