Hi I have a problem with inserting wav files of darksaber sounds. If I try to insert another file "on" it does not play, and it goes into error. The files are of identical size and quality. I do not understand what the problem is Also because they are files always belonging to projects related to python.
Some advice? thank you
Add a file wav darksaber
- tannewt
Re: Add a file wav darksaber
What is the error? You can see it by connecting to the serial output.
https://learn.adafruit.com/welcome-to-c ... al-console
- Filly66
Hi thanks, I simply put a file wav, with the specs of adafruit code, and wen I power on, don't work. I ama noob for this python. With other sound board is very simply to play a file. Sorry for my English I'm a Italian guy.
- Filly66
If I paste the files into it, could you be kind enough to compile the code? I noticed that you could put a momentary rgb button in place of latching, and put the power off file, which is missing when you turn off the darksword. Thanks in advance.
