CircuitPython Version: 7.1.1
Board: ESP32-S2 Feather
I'm trying to get myself familiar with clock routines - both getting the current time off the internet (with, of course, NTP) and for doing time-related functions on the controller.
I'm using the Adafruit ESP32-S2 feather boards. Following the examples I've found on the CircuitPython site, the sampe code wants to use the following libraries:
import time
import board
import busio
from digitalio import DigitalInOut
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_ntp import NTP
But I get "ImportError: no module named 'adafruit_esp32spi.adafruit_esp32spi'
I've read on some of the posts here that the Feather isn't compatible with the ESP32spi routines. What do I need to use the NTP routines?
(I've successfully connected to WiFi and have a functional MQTT client working with the BME280 sensor; so I'm just tying to get the library routines to allow me to get time from an NTP server - don't want to use the adafruit-specific servers).
Any help appreciated.
ESP32 Feather NTP libraries
- bonemender
Re: ESP32 Feather NTP libraries
did you copy the adafruit_esp32spi folder from the circuitpython-bundle lib folder to the feather's lib folder?
- karltbraun
Yes, but it's not an SPI board (for these features) so that didn't work.
- AmazingCircuitPythonFR35
I would also be very interested in a solution.
Indeed, the circuitpython module 'ntp' takes as argument an ESP_SPI (like airlift or other).
Can it work on a board with an ESP32-S2 where there is no wifi co-processor ?
Mike
Mike
- tannewt
Unfortunately the current NTP library is a bit of a lie. It just uses a NINA FW call to get the time.
However, I did make an actual NTP version here: https://github.com/tannewt/Adafruit_Cir ... ee/raw_ntp
Would you mind trying it and letting me know how it works? We can figure out how to swap them out soon.
Hi,tannewt wrote:Unfortunately the current NTP library is a bit of a lie. It just uses a NINA FW call to get the time.
I tried your 'adafruit_ntp' module (the one from github) but I get an error about the 'time' module.
The error says that the 'time' module does not contain a 'gmtime' attribute.
I tried replacing 'gmtime' with 'localtime' but I get another error.
Here are the contents of my 'code.py' file (I used a FeatherS2 with CPY 7.x):
# modules circuitpython natifs
import wifi
import socketpool
import time
# modules circuitpython externes (dossier lib)
import adafruit_ntp
# Récupère le SSID et le MDP du réseau WiFi dans le fichier secrets.py
try:
from secrets import secrets
except ImportError:
print("Fichier secrets.py non disponible")
raise
# *** CONNEXION AU RESEAU WIFI ***
print("Réseaux WiFi disponibles :")
for network in wifi.radio.start_scanning_networks():
print(f'\t{str(network.ssid, "utf-8")}\t\tRSSI: {network.rssi}\tCanal: {network.channel}')
wifi.radio.stop_scanning_networks()
print(f'Tentative de connexion au réseau {secrets["ssid"]}')
print("........")
wifi.radio.connect(secrets["ssid"], secrets["password"])
print(f'Connecté au réseau {secrets["ssid"]} !')
# *** RECUPERATION DE L'HEURE NTP ***
pool = socketpool.SocketPool(wifi.radio)
ntp = adafruit_ntp.NTP(pool)
while True:
print(ntp.datetime)
time.sleep(1)
- tannewt
What error do you get?
- Bill_r
Hi Tannewt,
I would also be interested in using NTP on the Feather ESP32-S2
The code below obtains time from Adafruit IO. I commented out that portion, imported your ntp library from github, and added the last two lines to get NTP time. However, this always returns an AttributeError:
Output in the repl is as follows:
Getting time... Traceback (most recent call last):
File "code.py", line 23, in <module>
File "/lib/adafruit_ntp.py", line 61, in __init__
AttributeError: 'module' object has no attribute 'gmtime'
Code done running.
Not sure if I missed something or not. Any assistance would be appreciated.
Thanks.
import time, board, adafruit_ds3231
import ipaddress, ssl, wifi, socketpool, adafruit_requests, secrets, adafruit_ntp
from rtc import RTC
ds3231=adafruit_ds3231.DS3231(board.I2C())
aio_username = secrets["aio_username"]; aio_key = secrets["aio_key"]; location = secrets.get("timezone", None)
TIME_URL = "https://io.adafruit.com/api/v2/%s/integrations/time/strftime?x-aio-key=%s" % (aio_username, aio_key)
TIME_URL += "&fmt=%25Y-%25m-%25d+%25H%3A%25M%3A%25S.%25L+%25j+%25u+%25z+%25Z"
print("Getting time... ", end="")
requests = adafruit_requests.Session(pool, ssl.create_default_context())
response = requests.get(TIME_URL); times=response.text; times=times.split(" ")
print(times)
the_date=times[0]; the_time=times[1]; yday=int(times[2]); wday=int(times[3]); isdst=None
year,mon,mday=[int(x) for x in the_date.split("-")]
the_time=the_time.split(".")[0]; hour,min,sec=[int(x) for x in the_time.split(":")]
ds3231.datetime=RTC().datetime=time.struct_time((year,mon,mday,hour,min,sec,wday,yday,isdst)) #set rtc to internet timetime: "
print ("Time: ",time.localtime())
ntp=adafruit_ntp.NTP(pool)
print(ntp.datetime)
Code done running.
Thanks.
- tannewt
Bill, try replacing gmtime with localtime and then let me know what the error is. I developed this library on desktop (aka CPython) which has more functions than CircuitPython does.
- Bill_r
OK, replaced gmtime with localtime in two places in the library. Error is now:
OverflowError: timestamp out of range for platform time_t
Code done running.
Bill
Code done running.
Bill
- Bill_r
OK - a little further testing.
commented out lines 61 & 62 in the library
Results are now:
code.py output:
Getting time... struct_time(tm_year=2022, tm_mon=3, tm_mday=4, tm_hour=18, tm_min=56, tm_sec=22, tm_wday=4, tm_yday=63, tm_isdst=-1)
Code done running.
Looks pretty good to me!
Bill
# if time.localtime(0).tm_year != 1970:
# raise OSError("Epoch must be 1970")
code.py output:
Code done running.
Bill
- tannewt
Nice! That looks good.
Hello,tannewt wrote:Nice! That looks good.
It works perfectly well for me too!
Great!
Would it be possible to modify the official version of the library in the CircuitPython library bundle?
Thank you.
Mike
- tannewt
Unfortunately, it isn't very easy to do because other libraries use this one. We've got an issue to track this here: https://github.com/adafruit/Adafruit_Ci ... /issues/16
