ESP_BUSY in use
teltech84
ESP_BUSY in use
Post by teltech84 »
My code runs the first loop fine but when running a second loop it returns an "Some error occured, retrying! - ESP_BUSY in use" error.
Does anyone know why this happens on my pyportal?
import time
import board
from adafruit_pyportal import PyPortal
textrow = 0
authorrow = 0
def main(textrow, authorrow):
    # Set up where we'll be fetching data from
    DATA_SOURCE = "http://192.168.1.67/presently-backup.json"
    QUOTE_LOCATION = [textrow, 'text']
    AUTHOR_LOCATION = [authorrow, 'author']
    # the current working directory (where this file is)
    cwd = ("/"+__file__).rsplit('/', 1)[0]
    pyportal = PyPortal(url=DATA_SOURCE,
                        json_path=(QUOTE_LOCATION, AUTHOR_LOCATION),
                        #status_neopixel=board.NEOPIXEL,
                        default_bg=cwd+"/quote_background.bmp",
                        text_font=cwd+"/fonts/Arial-ItalicMT-17.bdf",
                        text_position=((20, 120),  # quote location
                                    (5, 210)), # author location
                        text_color=(0xFFFFFF,  # quote text color
                                    0x8080FF), # author text color
                        text_wrap=(35, # characters to wrap for quote
                                0), # no wrap for author
                        text_maxlen=(180, 30), # max text size for quote & author
    # speed up projects with lots of text by preloading the font!
    pyportal.preload_font()
    value = pyportal.fetch()
    textrow = textrow + 1
    authorrow = authorrow + 1
    print("Response is", value)
    return value
while True:
    try:
        time.sleep(5)
    except (ValueError, RuntimeError) as e:
        print("Some error occured, retrying! -", e)
    time.sleep(5)
dastels
Re: ESP_BUSY in use
Post by dastels »
Try only creating one PyPortal object before the main function.
teltech84
Re: ESP_BUSY in use
Post by teltech84 »
Thanks for the reply Dave. This is what I've got so far based on your recommendations and it does remove the error although the code doesn't do what I wanted it to do.
I have a json file that has multiple key's.
[{"text":"testtext1","author":"author1"},
{"text":"testtext2","author":"author2"}]
I want my code to display testtext1, author 1 and then cycle back and display testtext2 author2 etc...
Currently it only retrieves the hardcoded value of testtext1 and author1.
Am I correct to think that if I call function PyPortal more than once it will error out and say it's busy? Do you know of a way to accomplish what I want to do?
import time
import board
#Set up where we'll be fetching data from
#the current working directory (where this file is)
    textrow = 0
    authorrow = 0
    return value
while True:
    try:
        time.sleep(5)
    time.sleep(5)
dastels
Re: ESP_BUSY in use
Post by dastels »
You'll likely have to do a bit more work. Fetch the json yourself (well, your code) and loop through it extracting the two bits of information and displaying them. This is a little different than the basic usecase for the portal stuff.
When you have:
That gets done once, i.e. textrow and authorrow are looked up then and used to create the lists. You are then passing those lists to the portal constructor. It doesn't matter if you later change textrow and authorrow... they aren't related to those lists at all, so the lists never change.
Also,
can be done above as well since it only has to be done once.
teltech84
Re: ESP_BUSY in use
Post by teltech84 »
So the following snippit can only be displayed once correct? It displays data to the screen. Should I be using another function to refresh or update that information? Because it seems like if I call this twice it errors out.
dastels
Re: ESP_BUSY in use
Post by dastels »
I believe
pyportal.fetch()
is for that.
teltech84
Re: ESP_BUSY in use
Post by teltech84 »
Thank you I got the loop to work! If I replace the json value in each loop it updates the data that's retrieved.
import time
import board
import json
i = 0
QUOTE_LOCATION = [i , 'entryContent']
AUTHOR_LOCATION = [i , 'entryDate']
var = (QUOTE_LOCATION, AUTHOR_LOCATION)
def main(i):
    pyportal.json_path=([ i,
                        'entryContent'],
                        [ i,
                        'entryDate'],
while True:
    try:
        main(i)
        i = i + 1
        time.sleep(5)
    time.sleep(5)
dastels
Re: ESP_BUSY in use
Post by dastels »
Well done!
