There seems to be a small problem with my New QT Py & Windows 10.
After installing the latest CircuitPython on it, the board responded by sleeping for a few seconds then triggering the USB connection, which is normal, same as my other CircuitPython boards.
However, there is a Windows 10 Message warning about a USB problem.
Everything seems to work fine, except for the warning message, which comes up with each reset & when the QT Py is plugged in...
Again QT is the only CircuitPython board that does this.
James
QT PY & Windows 10 USB ?
- danhalbert
Re: QT PY & Windows 10 USB ?
1. Which Qt Py is this?
2. What is the warning? Could you take a screenshot?
You can clean up USB devices on Windows. Unplug the board and try this:
https://learn.adafruit.com/welcome-to-c ... 3094694-11
