I use the Feather Sense for a lot of industrial projects.
I have an open request to add TX_POWER to the start_scan to increase the power above the default 0dBm for longer range, to no avail.
I did notice, that the _bleio.Adapter.start_advertising() has a TX_POWER input, and I thought I would give it a try.
Thinking, that if I started advertising and then stopped, maybe the power level would persist.
I have the Nordic scanner on my phone and a PPK2 to monitor power.
I went into the /lib/adafruit_ble/ folder and replaced the __init__.mpy with the __init__.py
I added the following "tx_power", starting at line 195 in __init__.py
else:
self._adapter.start_advertising(
advertisement_bytes,
scan_response=scan_response_bytes,
connectable=advertisement.connectable,
interval=interval,
tx_power = 0,
timeout=0 if timeout is None else timeout,
But, changing the tx_power=8 or 0 etc, doesn't effect the power of the transmission.
I know this through the Nordic scanner on my phone, always reading 4dBm and the current never changing in the PPK2.
So, this a bug, or am I missing something?
thx
