Is this possible?
thorangutang
Is this possible?
Post by thorangutang »
Hi there been at this for a while and have yet to determine if it can be done in Circuitpython so let me try a general question.
On a Feather ESP32-S2, is it possible to listen for UDP(or other wifi comunication) receive a message and use this to step a stepper motor while listening for new commands? So the Feather needs to listen for new commands and step the stepper at the same time
In c++ one would do something like the following to receive the UDP:
Udp.read();
  int size;
  if ((size = Udp.parsePacket()) > 0) {
    while (size--)
      msg.fill(Udp.read());
    if (!msg.hasError())
//then stepper code
But I cannot for the life of me figure out how to do this in Circuitpython.
Can anyone point me in the right direction?
Thank you!
danhalbert
Re: Is this possible?
Post by danhalbert »
You could use asyncio (https://learn.adafruit.com/cooperative- ... th-asyncio) and check whether there is activity on an incoming socket, using a non-blocking socket. I am not sure of the best way to do that. We're working on an asyncio requests library: viewtopic.php?f=60&t=191307
