I have a program I am trying to get polished up. The issue is that using Thonny, hitting "stop" or control C dors not immediately stop the program, it may take several minutes to come back to the REPL prompt.
What is the syntax for adding an 'exception' to a ^C or some such so that the program will react more quickly?
Roger
how to set up an escape?
- mikeysklar
Re: how to set up an escape?
ctrl-C is the correct command to stop the running program from the REPL.
ctrl-D will reload the code.
https://learn.adafruit.com/welcome-to-c ... n/the-repl
You could also stop the running program from within the code with quit(), exit() and sys.exit().
- Rcayot
Thanks Mike.
My problem is that repeated control-C presses take up o two minutes to respond. I thought that adding an exception for keyboard interrupt would help.
Roger
Roger
- tannewt
Please post the code you are running. We have had bugs where native code includes loops that ignore CTRL-C. Sharing the code can help us determine if that is the case here.
- Rcayot
here is the problem code.
# SPDX-FileCopyrightText: 2020 Jerry Needell for Adafruit Industries
#modified by Roger Ayotte 11/12/2021
# Example to send a packet periodically between addressed nodes with ACK
import time
import board
import busio
import digitalio
import analogio
import asyncio
#import adafruit_bme280
import adafruit_rfm9x
#import adafruit_ahtx0
adcV= analogio.AnalogIn(board.VOLTAGE_MONITOR)
voltage = adcV.value
adcW=analogio.AnalogIn(board.GP26)
wind = adcW.value
# Create library object using our Bus I2C port
from adafruit_bme280 import basic as adafruit_bme280
# i2c = board.I2C() # uses board.SCL and board.SDA
i2c = busio.I2C(scl=board.GP17, sda=board.GP16)
bme280 = adafruit_bme280.Adafruit_BME280_I2C(i2c)
bme280.sea_level_pressure = 1013.25
i2c1=busio.I2C(scl= board.GP15, sda = board.GP14)
newsensor = adafruit_ahtx0.AHTx0(i2c1)
# set the time interval (seconds) for sending packets
delay_interval = 600
Wdelay_interval = 30
Wcount = 0
# Define radio parameters.
RADIO_FREQ_MHZ = 915.0 # Frequency of the radio in Mhz. Must match your
# module! Can be a value like 915.0, 433.0, etc.
# Define pins connected to the chip.
# set GPIO pins as necessary -- this example is for Raspberry Pi
CS = digitalio.DigitalInOut(board.GP5)
RESET = digitalio.DigitalInOut(board.GP6)
# Initialize SPI bus.
# for Adafruit boards
#spi = busio.SPI(board.SCK, MOSI=board.MOSI, MISO=board.MISO)
# for PICO
spi = busio.SPI(clock=board.GP2, MOSI=board.GP3, MISO=board.GP4)
# Initialze RFM radio
rfm9x = adafruit_rfm9x.RFM9x(spi, CS, RESET, RADIO_FREQ_MHZ)
# Optionally set an encryption key (16 byte AES key). MUST match both
# on the transmitter and receiver (or be set to None to disable/the default).
#rfm69.encryption_key = (
# b"\x01\x02\x03\x04\x05\x06\x07\x08\x01\x02\x03\x04\x05\x06\x07\x08"
# set delay before sending ACK
rfm9x.ack_delay = 0.1
# set node addresses
rfm9x.node = 3
rfm9x.destination = 2
# initialize counter
counter = 0
ack_failed_counter = 0
# send startup message from my_node
rfm9x.send_with_ack(bytes("startup message from node {}".format(rfm9x.node), "UTF-8"))
# Wait to receive packets.
# print("Waiting for packets...")
# initialize flag and timer
weather_time_now = time.monotonic()
wind_time_now = time.monotonic()
async def get_temperature2(interval):
while True:
temperature = str(round((newsensor.temperature), 2))
#temperature = round(temperature, 2)
#temperature=str(temperature)
rfm9x.flags=1
print(rfm9x.flags, temperature)
if not rfm9x.send_with_ack(temperature.encode("utf-8")):
print("No Ack T")
await asyncio.sleep(interval)
async def get_humidity(interval):
while True:
humidity = (newsensor.relative_humidity)
humidity = round(humidity, 2)
humidity = str(humidity)
rfm9x.flags=3
print(rfm9x.flags, humidity)
if not rfm9x.send_with_ack(humidity.encode("utf-8")):
print("No Ack H")
async def get_pressure(interval):
while True:
pressure = (bme280.pressure)
pressure = round(pressure, 1)
pressure = str(pressure)
rfm9x.flags=2
print(rfm9x.flags, pressure)
if not rfm9x.send_with_ack(pressure.encode("utf-8")):
#ack_failed_counter += 1
print(" No Ack P")
async def get_voltage(interval):
while True:
#voltage = (adcV.value)
voltage = str(round((adcV.value*3.3*3/65535), 2))
#voltage=str(voltage)
rfm9x.flags=4
print(rfm9x.flags, voltage)
if not rfm9x.send_with_ack(voltage.encode("utf-8")):
print(" No Ack H")
async def get_wind(interval):
wsample = 0
wdata = []
WindAV = []
Wcount = 0
Awind = 0
while Wcount <=15:
for i in range(200):
wsample =(((adcW.value*0.00005035)-0.42)*32.4*(2.0-0.42))
time.sleep(.01)
if wsample < 0:
wsample = 0
wdata.append(wsample)
waverage = sum(wdata)/len(wdata)
wdata.clear()
WindAV.append(waverage)
Wcount = Wcount + 1
if Wcount == 15:
Awind = sum(WindAV)/len(WindAV)
Awind = round(Awind, 2)
Awind = str(Awind)
rfm9x.flags = 5
print(rfm9x.flags , Awind)
if not rfm9x.send_with_ack(Awind.encode("utf-8")):
print("No Ack W")
rfm9x.flags = 6
Gust = max(WindAV)
Gust=round(Gust, 2)
Gust = str(Gust)
print(rfm9x.flags, Gust)
if not rfm9x.send_with_ack(Gust.encode("utf-8")):
print("No Ack W")
WindAV.clear()
Wcount = 0
async def main():
temperature2_task = asyncio.create_task(get_temperature2(delay_interval))
pressure_task = asyncio.create_task(get_pressure(delay_interval))
humidity_task = asyncio.create_task(get_humidity(delay_interval))
voltage_task = asyncio.create_task(get_voltage(delay_interval))
wind_task = asyncio.create_task(get_wind(Wdelay_interval))
await asyncio.gather(voltage_task, pressure_task, humidity_task, wind_task, temperature2_task) # Don't forget "await"!
await(voltage_task)
asyncio.run(main())
- tannewt
What is the backtrace you get when it finally does get interrupted? That should tell us where it gets stuck.
- Rcayot
Not sure there is one. I will try a few more times and captue the info.
