hi everything was going great till i tried to change the look of the eyes, made a few mistakes and the mask froze. could not get into it.
i reset the mask and clear it memory as per instruction. at the moment i am getting this purple snake in the left screen top left.
i cant get into the mask by usb, any ideas ?
monster mask rest, usb wont pick up mask
- dastels
Re: monster mask rest, usb wont pick up mask
The snake generally means CircuitPython is running.
What do you mean by "I can't get into the mask by usb"?
- lm2425
when the mask is connected to the pc by usb, its does not pick it up , but it does pick it up when the reset button is pressed.
- dastels
When you reset, how does it "pick it up". Does a flash drive mount?
- lm2425
when you press the reset it works great after that, it does not pick it up at all tired it with 2 separate usb cabels on 2 different pc's.
- dastels
OK. But you didn't answer by question.
- lm2425
the monster mask is connected to the pc by a usb cable, it only shows up as F: circuit boot drive, when you press the reset button twice. after that you can not get access from the pc to the mask.
- dastels
Have you read and followed the instruction in the tutorial guide to update the bootloader, install CircuitPython to format the flash filesystem/drive, and install eye code? https://learn.adafruit.com/adafruit-monster-m4sk-eyes
- marcky
Hi Dave,
i'm in the exact same situation with 2 masks (the first one i've bought and the replacement unit).
Thank you
I've done all of the instructions on the troubleshooting page you mentioned and tried everything from your documentations in order to make the CIRCUITPY drive re-appear, but nothing works. CircuitPython runs fine, i can access it from Mu editor in safe mode, but the drive never appear. Please help to solve this.dastels wrote:Have you read and followed the instruction in the tutorial guide to update the bootloader, install CircuitPython to format the flash filesystem/drive, and install eye code? https://learn.adafruit.com/adafruit-monster-m4sk-eyes
Thank you
- lm2425
hi i got the usb to open up the mask but i think there some problems with the files, windows does not give anoth time to open the files and delete but it just crashes. i no its a hazel 1 file that is making it crash and i cant get into it to delete before it crashes.
- dastels
Have a look at https://learn.adafruit.com/welcome-to-c ... 2978456-26. You might need to use erase_filesystem to rebuild teh flash filesystem.
- marcky
Dave, for me the storage.erase_filesystem() command did not work. Any other suggestion? Thank you
- dastels
You mean did not change the behavior?
- marcky
Yes, exactly. I tried everything from your documentation, both masks does not load the CIRCUITPY drive.dastels wrote:You mean did not change the behavior?
- dastels
Anti-virus software will sometimes interfere.
