Macro keyboard works on computer but not on recorder.
MikeAelbrecht
Post by MikeAelbrecht »
So I made a macro keyboard using the pico and the usb_hid library.
When I connect the macro keyboard to my dektop is works how it should but when I connect it to my recorder https://cdn.sounddevices.com/wp-content ... 041122.pdf it stops working, when pressing a macro the program just crashes. I used USB Tree viewer and there I see that the pico is listed as Keyboard (that is what I programmed in boot.py) but also as Audio https://imgur.com/QulPcRM. Could this cause the problem or could it be something else, and does anyonne have a idea how to fix this problem.
danhalbert
Re: Macro keyboard works on computer but not on recorder.
Post by danhalbert »
Yes, it's a composite device, which your recorder may not like. The "audio" in this case means MIDI, and you can disable MIDI (and other functions). See https://learn.adafruit.com/customizing- ... cuitpython.
It may still be the case that your recorder also doesn't like the fact that it's presenting as both a mouse and keyboard. You can then also disable the mouse.
MikeAelbrecht
I disabled MIDI and Mouse so the pico is only visible as a Keyboard but still no luck. I also have storage disabled but I don't think that would be the problem. But worth noting is that the program doesn't start up anymore when plugged in... Normaly the program starts and on the press of a maco it crashes but now it doesn't do anything.
danhalbert
Check BOOT_OUT.TXT to see if there are any errors being printed during the boot.py execution.
MikeAelbrecht
No, there are no errors in boot_out that is what I find weird…
danhalbert
Are you saying that it now doesn't work on the computer as well? Could you post your code here?
MikeAelbrecht
It does work on the computer but not on the recorder, I’ll post my code tomorrow.
danhalbert
Did you try ` usb_hid.enable((usb_hid.Device.KEYBOARD,))` to make it a keyboard only?
This user had a similar issue when trying to emulate a mouse for a Nintendo Switch: https://github.com/dglaude/Wii_uDraw_fo ... ndo_Switch
The Switch did not like that the mouse was still contained in a composite device, so he had to create a mouse-only device.
It's not too hard to create a keyboard-only device. Here is a standard USB HID report descriptor for a keyboard:
https://github.com/praeclarum/circuitpy ... ors.py#L57. Remoe the surrounding stuff, and remove line 60.
MikeAelbrecht
Yes, this is my boot.py file:
import storage
import board, digitalio
import usb_hid
import usb_midi
# Initialize a button on GPIO0 or pin 1 of the pico
button = digitalio.DigitalInOut(board.GP0)
button.direction = digitalio.Direction.INPUT
button.pull = digitalio.Pull.DOWN
# Disable devices only if button is not pressed.
if not button.value:
   storage.disable_usb_drive()
# Disable MIDI control
usb_midi.disable()
# Set the device as a keyboard only
So I set the pico only as a Keyboard.
I use the build in Keyboard HID that came with the libraries, that should work aswell right?
danhalbert
I use the build in Keyboard HID that came with the libraries, that should work as well right?
Sorry for the delay, yes, that should work.
MikeAelbrecht
No problem! The error kept occurring and I remade it using an arduino pro micro and the same issue happens, so the recorder handles HID inputs a bit weird I guess
