MagTag Battery Monitor
I have several MagTag devices, They show me the data from my ecowitt sensors. Everything is working nicely. But I like to know in advance, when the time has come to load again the 3.7V 2000mAH LiPo (LP803860). I am using the often proposed function from the magtag library “magtag.peripherals.battery” it always shows something above 5 Volt on all MagTag devices. The value does not change over the time, after weeks of running the display remains blank, as the power needed for the next refresh of the display is no more available. Then I am going to use the USB-C connector to charge the LiPo and as soon a the yellow charging LED switches off, I distribute the device again in the house. I am pretty sure there is some bug within the library, as also the documentation explains how the value will change and how to recognize a soon power outage. Could someone explain what is going wrong?
- dastels
Re: MagTag Battery Monitor
The first thing is to ensure that CircuitPython and all libraries are up to date.
Thanks Dave
It was and it is adafruit-circuitpython-adafruit_magtag_2.9_grayscale-en_US-7.2.5
Any other ideas?
Any other ideas?
- dastels
What do you see in terms of data if you read AnalogIn(board.BATTERY) over time?
This is the code I am executing
I do have 5 magtag devices, so the result varies a little bit, I do see 5.11 or 5.35
The point is this value never changes over the time, where the real battery voltage gets lower and lower
Thanks for support
from adafruit_magtag.magtag import MagTag
magtag = MagTag(
url=...,
json_path=...,
voltage = magtag.peripherals.battery
print(f'battery: {voltage:.2f} V')
Thanks for support
I have added this part
The result over the serial line is
magtag.peripherals.battery and AnalogIn(board.BATTERY)
return a similar value
from analogio import AnalogIn
batt_Monitor = AnalogIn(board.BATTERY)
battV = (batt_Monitor.value / 65535.0) * 3.3 * 2
batt_Monitor.deinit()
print(f'battery: {battV:.2f} V')
code.py output:
battery: 5.11 V
battery: 5.11 V
And if I do not do the "mathematics" it look like this
code.py output:
battery: 50739.00 V
battery: 5.11 V
so AnalogIn(board.BATTERY) returns 50739
code.py output:
battery: 50739.00 V
battery: 5.11 V
- dastels
I've asked internally to get some more eyes on it.
- adafruit_support_carter
This may be related to this:
https://github.com/adafruit/circuitpython/pull/6246
Try updating to the 7.3.0 release which *should* fix that behavior:
https://circuitpython.org/board/adafrui ... grayscale/
Here's a simple battery voltage monitor program you can try testing with:
import time
magtag = MagTag()
magtag.add_text(
text_position=(
10,
(magtag.graphics.display.height // 2) - 1,
text_scale=3,
while True:
magtag.set_text("Battery = {:4.2f}V".format(magtag.peripherals.battery))
time.sleep(60)
Yes, this is more or less what I doing, getting some Information from web services AND add the battery status and display everything
Update every 5 minutes
As far as I understood, I should do not grap the battery voltage at the beginning but after log into WIFI and web queries
The approach to read out the battery voltage as late as possible, while still running on version 7.2.5 returns a reasonable result.
After updating to 7.3.0, both readings, the one at the beginning and the one after web access return the same good result
Thank you !
Thank you !
