Hi, as I am following the tutorial to install CircuitPython Libraries on MicroPython using the Raspberry Pi Pico (https://learn.adafruit.com/circuitpytho ... -libraries), i cannot find the file adafruit_blinka/microcontroller/rp2040.py on the latest Blinka from the link in the tutorial.
Moreover, I cannot even upload the file "Adafruit_Blinka-7.3.0\src\adafruit_blinka\microcontroller\rp2040" (which by the way only containes i2c.py, pin.py, spi.py, __init__.py, uart.py). It gets me the error:
RuntimeError: Could not open file /lib/adafruit_blinka/microcontroller/rp2040/__init__.py for writing, output:
[Errno 2] ENOENT
Thanks for the help :)
Installing BLINKA in MicroPython Pico
- neradoc
Re: Installing BLINKA in MicroPython Pico
Hi, what are you using to upload the files ?
__init__.py is empty (it's needed for the setup script to know it's a module, but it's not needed otherwise)
And I believe it's possible that some tools have an issue with uploading empty files.
- Nicolebendo
I'm using the "Files" section of Thonny
